Tire size for 1978 z1r front?
- z101mike
15 Jul 2017 16:50
anyone know what the stock tire size would be for a 1978 z1r kz1000
Re: Tire size for 1978 z1r front?
15 Jul 2017 17:59
The original tire size for the 1978 KZ1000-D1 (Z1R) was 350H-18. See:
www.powersportswarehouse.com/p/Kawasaki#...0-D1-1978/070081D-14
That tire / wheel size changed on the 1980 KZ1000-D3 (Z1R) to 325V-19. See www.powersportswarehouse.com/p/Kawasaki#...00-D3-1980/070081L-3
- z101mike
15 Jul 2017 19:20
Ok, there is something fishie,I bought a new tire 110/90 18 and its too big,wont go through the fender bolts.I guess ill go to a 90/90 18 thanks
15 Jul 2017 20:36 - 15 Jul 2017 20:36
I certainly would not put a 90/90 tire on it. That is too skinny. I would use the correct metric equivalent tire which is 100/90. That's what I've always used on my KZ650, and if it fits the KZ650 it certainly should fit the KZ1000. The link below may help you with sizes. Ed
www.maxxis.com/other-motorcycle-informat...torcycle-tire-school
Last edit: 15 Jul 2017 20:36 by 650ed.
The following user(s) said Thank You: z101mike
- z101mike
15 Jul 2017 23:23
I took the fender bolts out, put the tire on,then put them back.Its close but I think ill be ok.
