ZRX shocks on KZ1100
  • 76KZ900
  • 76KZ900's Avatar Topic Author
14 Jul 2017 22:09
#766979
I just bought a set of these off the ZRXOA forum. Im hoping these will ride a little better than the stock KZ shocks. Is this the case ? If you have this conversion I'd like to hear from you
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
76KZ900 (sold) regret
03ZRX1200R (sold) regret
83KZ1100 LTD Shaft
  • madmatt1
  • madmatt1's Avatar
Re: ZRX shocks on KZ1100
15 Jul 2017 16:56
#767031
Those are the KYB piggyback shocks, yes? I have not personally tried them, have been real tempted to though. Other guys have done this and said they were very pleased with the outcome. I think they are about a half inch longer than the stockers. Honestly, I don't see how they couldn't be better than the originals. Give her a go! I'd like to hear what you think about them!
1977 KZ1000 LTD
1979 KZ1000 LTD
1978 KZ1000A
  • 76KZ900
15 Jul 2017 21:22
#767053
Yes on the piggy back KYB. No kidding on gotta be better than the originals. I'm 250 and have the preload set at lightest point and they are still pretty rough. I have a friend with a Suzuki GS850 and rides much nicer.
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
16 Jul 2017 04:25 - 16 Jul 2017 04:27
#767063
I run them on my Z1B. I spaced out the left shock with washers to clear the chain. Also had to rebuild them due to failing bladders. Good damping, easier on my back.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 16 Jul 2017 04:27 by Kidkawie.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
16 Jul 2017 12:16
#767088
I run them on my GPZ750. They work well but I did have to remove the helmet lock due to interference.
I also had to mod the chain guard to clear.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • 76KZ900
16 Jul 2017 14:22
#767099
Kidkawie wrote: I run them on my Z1B. I spaced out the left shock with washers to clear the chain. Also had to rebuild them due to failing bladders. Good damping, easier on my back.
Did you rebuild them yourself ? Or send them to someone? What was the price of rebuild ? Thanks
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
  • madmatt1
  • madmatt1's Avatar
16 Jul 2017 15:45
#767109
Nice, Kidkawie, they sure look sharp on your bike! Fit right in with that paint scheme!
1977 KZ1000 LTD
1979 KZ1000 LTD
1978 KZ1000A
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
16 Jul 2017 18:27 - 16 Jul 2017 18:30
#767125
Thanks!
I rebuilt them myself. I used heavy duty zip ties to compress the spring, couldnt find the exact length bladder but have the part number for one thats close, used 2.5wt shock oil. Cost about $50 for both. I have to look but I think I have some documents on rebuilding/bleeding them. They are 1/2" or so longer but it doesnt seem to make any difference when theres weight compressing them.
I also did tgat mod where you cut off the spring preload adjuster tabs which lets you use the upper housing as new tabs. The inner sleve gets loose so I took it a step more and welded the inner sleve to the preload adjuster.
1975 Z1 900
2004 KX125
Last edit: 16 Jul 2017 18:30 by Kidkawie.
  • 76KZ900
17 Jul 2017 12:56 - 17 Jul 2017 13:27
#767184
[/attachment]
What is this mod you speak of ? I just mounted my shocks up and it seems to sit my bike up a little higher than I like. Ill post some pics later
Anyone what are my options for lowering the rear if I choose to do so ?
Inserted pic.. Im kinda torn .. Half of me says it looks like a dirt bike.. Half says it looks ok.. Def rides nicer
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
Last edit: 17 Jul 2017 13:27 by 76KZ900.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
17 Jul 2017 14:10 - 17 Jul 2017 14:11
#767195
Ill try to get some pics tomorrow, but you basically remove the preload adjuster nubs then use the upper housing instead. Besides that, you can put limiters inside the shock.
1975 Z1 900
2004 KX125
Last edit: 17 Jul 2017 14:11 by Kidkawie.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
18 Jul 2017 07:43
#767243
See pics. With the nubs removed from the inner sleeve, the sleeve can fall inside the shock because nothing is holding it up anymore. I indexed the inner sleeve with the preload adjuster ring and welded them together. You cannot remove the inner sleeve alone because then there will be too much slop between the shock body and the preload adjuster. Static weight on the shocks they measure 13.25" eye-to-eye. Tha bladder I used is 46mm x 88mm, part #120104600101, original bladder is65mm long, Race Tech sells original size for $100/ea but it's not that crucial IMO.
1975 Z1 900
2004 KX125
The following user(s) said Thank You: 76KZ900
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
18 Jul 2017 07:53 - 18 Jul 2017 07:53
#767244
If you want lower than that, you need to fab up some limiters out of UHMW polyethene rod. Buy a foot of it (McMaster Carr) in a diameter smaller than your shock ID and chop off a coupla pieces on the band saw or lathe.
1975 Z1 900
2004 KX125
Last edit: 18 Jul 2017 07:53 by Kidkawie.
