Clutch cable
  • missionkz
  • missionkz's Avatar Topic Author
Clutch cable
13 Jul 2017 19:04
#766880
Bummer..... +40,000 miles on my KZ1000A clutch cable and it broke two nights ago right at the lever/barrel end.
I was 18 miles from home, across town with my wife on board.
That was a juggling act to get home...jeeze!
The only good cable I have is cheap $15 motion pro cable from, who knows when I bought it.
Looks light weight compared to my original Kaw cable.
I installed it anyhow but....??
Thoughts or comments?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • bluej58
  • bluej58's Avatar
Re: Clutch cable
14 Jul 2017 03:27 - 14 Jul 2017 03:34
#766900
40,000 is impressive, I ran into the same problem and ended up going to Kawasaki for a fresh one.
How old is the motion pro cable you have? I hope they fix the problem.
I always carry a back up cable with me and have only had to go to it once in 6 years,
It can be a real problem if you are a long way from home with no clutch.
The crappy mp cable might be an OK back up but i wouldn't trust it for the long hauls
78 KZ1000 A2A
Last edit: 14 Jul 2017 03:34 by bluej58.
  • Nessism
  • Nessism's Avatar
Re: Clutch cable
14 Jul 2017 05:14
#766904
The cable end needs to be lubricated so the ball end can rotate. That helps extend cable life. 40k is good life though. I'd order up a new OEM cable.
  • KZB2 650
  • KZB2 650's Avatar
Re: Clutch cable
14 Jul 2017 14:41
#766945
My 3 cables are all original and after 39 years of abuse (although I do lube em and grease em well too) I'd never use anything else if one ever decides to break...... Maybe its time but no fraying and still smooth so I hate to even touch em.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • RonKZ650
  • RonKZ650's Avatar
Re: Clutch cable
14 Jul 2017 18:10
#766966
Buy the original if possible, but I doubt highly Kawasaki still offers the cable. They discontinued the KZ650 cables about 15yrs back. I would guess the KZ1000 likewise. Motion Pro cables are not too bad.
  • ayeckley
  • ayeckley's Avatar
Re: Clutch cable
15 Jul 2017 11:15
#767004
I just installed the PMC clutch kit on my KZ1000 to prevent this problem and make the bike more fun to ride. I predict it will be worth the $110 but time will tell.
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1 aka GPz 750
1983 ZX750 A1
1973 CL350K4
1984 ZX1100 A2 aka GPz1100
1969 CT90
2006 Burgman 400
  • Shabba
  • Shabba's Avatar
Re: Clutch cable
15 Jul 2017 19:54
#767046
missionkz wrote: Bummer..... +40,000 miles on my KZ1000A clutch cable and it broke two nights ago right at the lever/barrel end.
The cable on my GPZ got so bad last month that I replaced mine. I was able to find OEM from Partzilla. My cable, which I could have used a little longer with a good lube, did a respectable 30k on this bike and that was with minimal lubing (if at all) from the previous owners. 40k is pretty damn good.
-Colin
-82 GPZ750
-15 Yamaha FZ-09
-00 Suzuki TL1000S
-13 Nissan Nismo Juke
  • kzdcw
  • kzdcw's Avatar
  • 77' KZ1000A
Re: Clutch cable
25 Jul 2017 04:07
#767671
My 77' KZ1000A "stock" clutch cable is also starting to fray at the barrel end. Bike has Superbike handlebars.
So which cable would you recommend if Motion-Pro is not all that good ?
77' KZ1000A
  • davido
  • davido's Avatar
Re: Clutch cable
25 Jul 2017 12:49
#767704
I just cant get my hydraulic set up to work so Im going to strip it off and refit the original cable set up.I have all the parts including the cable but its well frayed.I hope it ll hold up for a while as I dont want to buy a new one. (Ill eventually put the hydraulic system back on once I figure out how to get it working right). Kawasaki still do an original cable for my CSR though its not cheap. a company called 'Slinky' does a pattern version. It seems a quite popular brand but I havent had any experience with them.
I did change the bars on my bike and had to shorten the throttle cable. A simple job of snipping the old nipple off and soldering on a new one,after shortening the sleeve.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
