quick turn throttle
- DoctoRot
quick turn throttle
02 Jul 2017 01:48
Has anybody used one on their KZ? I mostly want it to give the me some space from the kill switch as i keep accidentally bumping it off, but Also a being able to go WOT with-out re-positioning my hand would be great.
Re: quick turn throttle
02 Jul 2017 06:13
Not on my KZ, but I had one on my BSA. If you install one be very careful when riding. When riding my BSA if I hit even a moderate size bump or pothole I would sometimes accidentally snap the throttle wide open. Thrill ride time! :woohoo: Ed
- CoreyClough
- GPz550 Addiction
02 Jul 2017 08:45
If you bike uses two throttle cables, one for opening, and one for closing, then Motion Pro can make a custom kit for you.
www.motionpro.com/featured/rev2_throttle
I have one on my 1985 GPz550, and am using CV32 Carbs from a ZX600 (A, B, C). Had to replace the stock on/off/start/stop switch with one of theirs, and wire it in. Once you fine one of the interchangeable "reels" you like, stay with it.
'85 GPz550(ZX550-A2)
- DoctoRot
02 Jul 2017 12:20
I was looking at the motion Pro Rev2 throttle but its kinda expensive. However the progressive cable pull is very interesting. Im looking at these as they are a bit cheaper
japan.webike.net/products/21345640.html
japan.webike.net/products/20875160.html
- CoreyClough
- GPz550 Addiction
04 Jul 2017 07:46 - 04 Jul 2017 07:48
Before you purchase that throttle assembly, e-mail Motion Pro Custom Cables, and let them reply.
Something additional to think about. The cable assembly has an amount of inner wire "free length". This free length(exposed inner wire) is shared between the throttle assembly, and the carb linkage. Change the carbs, and or the throttle, and you will have a different required free length. Too much free length, and the throttle will not open the carbs completely. Too little free length, and the carbs may not close completely. There are in-line adjusters to take up the excessive cable wire, making the housing longer. Also over time, the cable doesn't stretch, the housing compresses, making you run out of adjustment. It isn't that expensive to have a custom cable made for the throttle you are using, and the carbs too. You can trial and error with different cables, as there are some that might be close, but if you have the time, do it once, and do it right.
This is just my opinion.
Last edit: 04 Jul 2017 07:48 by CoreyClough.
- DoctoRot
04 Jul 2017 11:15 - 04 Jul 2017 11:20
the deal breaker for the motion pro throttle is I cant use my OEM kill switch, which i absolutely love the look of. I'm using cables i currently have that have the same mount of OEM slack. So far those cables will open the carbs completely and seem to work well on the RS34 carbs. The throttle sleeve i was using was ⌀ 28.5mm and i went to ⌀ 32mm on the new throttle, hopefully this makes it a bit easier to go to WOT but not make it too squirrely for the street. Only $16 for shipping from Japan.
Last edit: 04 Jul 2017 11:20 by DoctoRot.
