2 POT Front Disk Caliper mod for 77KZ650-B1 Spoked
  • howzit
  • howzit's Avatar Topic Author
01 Jul 2017 04:42
#765814
Is it possible and is there a part (Bracket and Caliper) available to modify my front disk braking system? I am looking for a 2 Pot caliper and bracket that I can use with my stock front wheel.
  • TwoCam
  • TwoCam's Avatar
Re: 2 POT Front Disk Caliper mod for 77KZ650-B1 Spoked
01 Jul 2017 05:41
#765820
I can't answer your question, but have you considered if your master cylinder will have enough volume for the larger caliper??? I ran into that issue when I installed the dual calipers on my 1000 years ago. Ended up putting a KZ1100 master on so it would stop. The single caliper master had too small a piston for the added caliper. Just a note to think about .
