Fork oil seal thickness - GPZ750 R1 (1982)
- HeavenlyMachines
29 Jun 2017 01:26
A few months ago I bought a pair of fork oil seal for my 1982 GPz750 R1.
It was too thick about 2mm and I could not fit the retainer ring. I looked at what's previously installed it was clearly grounded, perhaps using sandpaper. So I proceeded to do the same.
It did not last long and I need to get a proper one. Is it correct that certain version of GPz750 had thinner seal?
I found this thread discussing it:
www.kawasakimotorcycle.org/forum/mechani...r-clip-gpz750-2.html
Let the good times roll...
gpzninja.blogspot.com.au
Re: Fork oil seal thickness - GPZ750 R1 (1982)
29 Jun 2017 04:23
www.allballsracing.com/fork/55-110.html
www.biketeile24.de/de/fahrgestell/vorder...ing-satz-55-110.html
ID 36 mm x OD 48 mm x high 8 mm
29 Jun 2017 05:16
Two questions:
What was the Kawasaki part number on the seals you bought?
Are you positive the front forks on the bike are original?
29 Jun 2017 16:07 - 29 Jun 2017 22:10
Without part numbers, it's only guesswork. The aftermarket seal brands probably have got their x-ref wrong. The guy in the kaw mc dot org topic didn't bother to provide a part number either. webmoto doesn't provide part numbers & the fork seals they have listed for the 82 GPz seem to have the wrong dimension --- too thick.
Last edit: 29 Jun 2017 22:10 by martin_csr.
- Tyrell Corp
30 Jun 2017 07:34
Yes, a lot of ebay sellers are just selling 36mm oil seals, the 750R1 is shorter. Had this problem a while ago.
