Problem with New Chain??
- 79MKII
- Love Them Kaws!
26 Jun 2017 19:48 - 26 Jun 2017 19:50
Hello All,
I'm having a strange issue with a new chain and I'm wondering if anybody has seen this before. I went up 2 teeth on my rear sprocket and the chain wasn't long enough, so I ordered a longer one. I just installed everything and I can watch the chain swing side to side about a 1/4" or more. The chain is actually hitting the chainguard in one spot because of the excess side to side movement. My first thought was that the new rear sprocket must be bent, but the sprockets seem straight (although I haven't measured runout yet). Could an issue with the chain cause something like this? I've never heard of it, but it seems like I got a bad chain?? Would riding with the new chain "loosen it up" and maybe correct the issue?
Thanks
Thanks
The Kaw List:
Last edit: 26 Jun 2017 19:50 by 79MKII.
- retterath
Re: Problem with New Chain??
26 Jun 2017 20:24
I would be returning that chain. That's all kinds of wrong. Running it like that will destroy your sprockets.
26 Jun 2017 20:38
What size and kind is it?
- 79MKII
- Love Them Kaws!
27 Jun 2017 07:20 - 27 Jun 2017 07:40
I'm running a 530 conversion on my 1000. It's an off brand which I've had good luck with in the past. I just ordered a good EK chain so I'll try it when it gets here. I've just never seen a chain cause this type of problem....I hope that's it.
The Kaw List:
Last edit: 27 Jun 2017 07:40 by 79MKII. Reason: Corrected brand of new chain to EK
- 79MKII
- Love Them Kaws!
02 Jul 2017 12:41
The problem was with the brand new chain....what a piece of junk! It's like there's a big bend in it...never seen anything like it.
The new EK chain is perfect....no problems. I'm just glad that was it and not an output shaft bearing or bent sprockets or something weird like that. Just a cheap-@ss chain!
Learn something new every day!
The Kaw List:
02 Jul 2017 13:51
Great. Where did you get it?
- loudhvx
02 Jul 2017 13:59
Good thing you caught that. I don't think I would've checked for that with a new chain... unless it was making funky noises.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- 79MKII
- Love Them Kaws!
02 Jul 2017 15:31SWest wrote: Great. Where did you get it?
Place called Wincycles from eBay. I'll let you know if he is willing to issue a refund.
The Kaw List:
- 79MKII
- Love Them Kaws!
02 Jul 2017 15:33loudhvx wrote: Good thing you caught that. I don't think I would've checked for that with a new chain... unless it was making funky noises.
I just gave the wheel a quick spin while it was up on the stand and I could hear the chain hitting the chainguard. It was swinging side to side badly.
The Kaw List:
