rear brakes dragging
- freebyrd24
09 Jul 2006 21:07
im havin a big problem with the rear disc brake draggin on my 78 kz650sr. when i got the bike, it dragged a little bit so i went to bleed it, when i bled it, it shot a little out then nothing, no pedal. so i dissassembled the master cylinder and the calipers. master had a little surface rust on the piston and was frozen, fixed that, and got one of the caliper pistons out. i cant get the other one out. so i re assembled and now the brakes work, but they r dragging again.
1.) any good way to get that stubborn piston out of the caliper? (compressed air didnt work)
2.) is this causing my rear brake draggin issue?
thanks
thanks
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
Sold:
- wireman
Re: rear brakes dragging
09 Jul 2006 21:22
soak it with wd-40 or something like that fo a day or two then blow it out with air.
- jbw7300
- you can't ride if your fried
10 Jul 2006 03:40
you could take the caliper off the mount leave it connected to the master put a clamp on the good piston and use the master to pump out the bad piston, WARNING keep all fingers clear, try to get the piston to go in a bucket or just put it in a bucket if you can, also watch out for fluid it can ruin you day:P
this procedure could cause loud noises from your bucket or from the misses "going what the hell was that if he hurt himself again I'll kill em'":woohoo: don't ask about the later:P
84 kz 700 a1 sports
- freebyrd24
10 Jul 2006 19:21
how do i get a clamp on the good one to try to push it out using the master cylinder? i thot of this, but dunno how to rig it up to work
Sold:
Sold:
- jbw7300
11 Jul 2006 03:43
if you can't get a clamp in there try a piece of wood to hold the piston, get one that fits close and pump the master till the good piston comes in contact with the wood, then pump out the bad piston
84 kz 700 a1 sports
- freebyrd24
12 Jul 2006 16:32
worked like a charm, thanks everyone
Sold:
Sold:
- freebyrd24
16 Jul 2006 11:44
Upon reinstallation i found that the O-ring that goes between the two calipers is non-existant. could this cause more brake issues, like more of the brakes sticking due to air in the lines?
Sold:
Sold:
- freebyrd24
17 Jul 2006 18:14
any ideas?
Sold:
Sold:
- bobthebike
17 Jul 2006 20:57
I'm not sure of my nomenclature, but did you check the pins that the calipers slide on when they retreat after brake apllication. Mine were discovered sticking just yesterday. BTW, you might want to check those rubber boots for tearing. ,BK
- freebyrd24
18 Jul 2006 04:58
now that you mention it, those pins did have some crap built up on them, ill take it off and thoroughly clean those. is that what happened to yours?
Sold:
Sold:
- bobthebike
- freebyrd24
18 Jul 2006 12:18
if thats the cause of some dragging, then ill be thankful, thats an easy fix. hope it works
Sold:
Sold:
