KZ1100 shaft removal
- PiotrKZ
10 Jun 2017 12:35
I just won the fight with pivot bearing bolts that were seizured and 35 years not removed. Left side slide out with the force but anyway, but right one I had to drill larger hole (previous 5mm original I broke the bolt) for 8mm and after making a thread and very very big force ...it moves slightly out. So I have swing arm released, but can not figure out how to remove shaft from the tube/swing arm. So, I need information about that. Have Clymer service manual but there is nothing there.
- daveo
Re: KZ1100 shaft removal
10 Jun 2017 14:32
There is a circlip (#480) that needs to be removed.
See exploded parts view:
www.cmsnl.com/kawasaki-kz1100a2-shaft-19...t/62099.html#results
1982 KZ1100-A2 bike
1984 ZN/ZX1100 motor
The following user(s) said Thank You: GPz550D1, PiotrKZ
- PiotrKZ
11 Jun 2017 07:26
That was exactly the information I was looking for.
