Re-sleeving master cylinders?
- slmjim+Z1BEBE
06 Jun 2017 14:55 - 06 Jun 2017 17:32
We have some Z-1 master cylinders in need of being re-sleeved.
Has anyone had this done in the U.S. who could provide results and references?
Thanks for the assist!
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 06 Jun 2017 17:32 by slmjim+Z1BEBE.
Re: Re-sleeving master cylinders?
06 Jun 2017 15:01
I have not used these folks' services, but you may want to contact them and ask if they can do your master cylinders. Ed
www.karpspb.com/sleeving.htm
The following user(s) said Thank You: ezrider714
06 Jun 2017 15:21
You can try calling these guys too...
www.applehydraulics.com/motorcycles.htm
- ezrider714
06 Jun 2017 18:00 - 06 Jun 2017 18:00
Interesting....NO more excuse to tearing into that rear M/C now.
Awaiting delivery of rebuild kit for the front also, so bore worries now out of mind, I feel much better about starting these projects
Don't know why sleeving never crossed my mind.......
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere)
Dyna Coils
Last edit: 06 Jun 2017 18:00 by ezrider714.
- slmjim+Z1BEBE
12 Jun 2017 12:31
Hi all,
Two places we've contacted say they can do Z-1 MC's.
One claims their stainless steel sleeve is best 'cause it doesn't corrode. The other claims their hardened brass sleeve is best 'cause brass is, by nature, a bearing material.
Anyone here versed in the chemistry of DOT 3/DOT 4 brake fluid vs either sleeve material?
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
12 Jun 2017 12:55
Pretty sure brake fluid won't have any issue with these materials. I do know though that stainless in contact with aluminum can lead to corrosion, that's why anti seize is always recommended on stainless screws in aluminum. Brass is better but not as hard. Both are harder than aluminum though so a brass sleeve should be fine.
- Nebr_Rex
12 Jun 2017 18:44
Resleeving master cylinders is one of those projects that I have on the back burner.
I was considering stainless steel but brass would be easier to machine. And yes, stainless
steel does corrode. Just look into marine applications. It just takes a little longer.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
