KZ750 hub with kz650 rim?
- scotia1000
04 Jun 2017 22:42
Hi,
does anyone know if a kz750b twin, disc hub will work on a kz650 rim using kz750 spokes? I'm having trouble trying to find a 750 rim,
thanks
thanks
Re: KZ750 hub with kz650 rim?
05 Jun 2017 05:55 - 05 Jun 2017 06:02
Front or rear? According to the cross-reference at Partzilla for the 76 750-B1, it uses the same Fr rim as the 650B, 750B, 900A & 1000A. The 87-88 305 Fr is also listed in the x-ref, but I would double-check that to verify.
For the Rr only the 750B & 1000A are listed. The Rr rim is a 2.15 x 18 --- same as the 650B & I think they are all 40-spoke, but I don't know if they're interchangeable as the Rr spokes are different. I'm thinking the spoke hole angles could be different. ???
Last edit: 05 Jun 2017 06:02 by martin_csr.
The following user(s) said Thank You: scotia1000
05 Jun 2017 07:04
