Single clubfoot swingarm
- kawsakiman
11 May 2017 21:35
Ok, I heard somewhere you can modify a clubfoot swingarm to accept bearings so you can use shocks.
A rigid with my back will not work.
Was I wrong or do anyone in this vast knowledge base we call kzrider know if this can be done ?
Re: Single clubfoot swingarm
12 May 2017 04:36
Yes it can be done .. Its just not normally done as most clubfoots are run with struts instead of shocks . And you will need to make sure the outriggers on the swingarm clear the frame and anything else in the way of the pivoting arm
- kawsakiman
12 May 2017 20:56
Do you have pictures or a point of reference I can go to ?
Or do you know any place I can send mine to to have it done ?
13 May 2017 05:20Sorry no pictures as I havent done one in many years. The one I builtkawsakiman wrote: Do you have pictures or a point of reference I can go to ?
was designed for the outrigger clubfoot to pivot and to clear the frame where it could have hit by the rear foot peg mount
. Did you buy a arm you are trying to convert ? Pictures ?
Our 2 go to members here are Les Holt and Blackbanshee531 for this kind of work
- les holt
14 May 2017 06:48
I done one yrs ago, it's work and can get a little costly, it basically takes 1 and a 1/2 bearing kits, 2 kits come in around $220 or so plus you have labor, Could probably build a non clubfoot arm new for less money.
Les Holt
Les Holt
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- kawsakiman
15 May 2017 00:49
Less,
If you are interested, I will pay up front for you to do this or build me a 6 over arm.
Or trade mine.
It is fresh powder coated gloss black.
I just want suspension in the rear.
Pm me for the phone number.
It is a kosman arm so if anyone has an extended able to is shocks hit me up.
Or trade mine.
