1981 KZ650-D4 - Brake Master Cylinder and Handle
  • gordone
  • gordone's Avatar Topic Author
02 May 2017 14:12 - 02 May 2017 14:25
#761000
Hi,
I want to replace my old master brake cylinder and handle (whole assembly).
I have talked with different people and, they have suggested Brembo on ebay?
It`s a dual brake system I have, so it has to fit to my existing tubing...
Please see attached pictures from my bike.
Is it 5/8 inch I have ?
Do you know what I can use ? have you upgraded?
I also want to replace the clutch handle same time, so they have same design/look.
Project:
Last edit: 02 May 2017 14:25 by gordone.
  • Nessism
  • Nessism's Avatar
Re: 1981 KZ650-D4 - Brake Master Cylinder and Handle
02 May 2017 18:04
#761016
  • gordone
04 May 2017 03:51
#761136
No eBay APP ID and/or Cert ID defined in Kunena configurationSo these will work with my piping? That will be brilliant :)
If I purchase these also:
Then I have a complete set with same design and look?
Project:
  • Nessism
  • Nessism's Avatar
04 May 2017 04:50
#761137
If your bike still has the original brake lines they should be replaced. The rubber deteriorates and scale develops on the inside.
  • gordone
04 May 2017 05:09
#761138
I will replace them, but I need to know if the brake cylinder you find to be on ebay will fit the original brake lines?, so I can order identical to what I have.
Project:
  • Nessism
  • Nessism's Avatar
04 May 2017 05:47
#761139
That EX650 master has the outlet port at 90 degrees to yours. Look at the photos to see for yourself.
  • gordone
04 May 2017 08:31
#761156
I can see that, but I was more thinking about the dimension of fittings for the line. Will my line or a new one with same size fit these EX650 master cylinder?
"connection dimension", I don`t know the exact word :) hope you understand :)
Project:
  • gordone
12 May 2017 12:59
#761832
What has the forum member done, if you want to upgrade to newer brake cylinder, what do you with your mirrors? how to mount them?
I want both handles to have same design these mean I need to change both side...
Project:
