caliper rebuild
- khungerf
caliper rebuild
24 Apr 2017 12:01
Hello all, (been slacking and not working on the bike much)
I just pulled off the front calipers - one is 'sticky'
Assuming I should rebuild/replace both of the calipers ( a guess)
What rebuild kit do you recommend.
1984 GPZ 550
1984 GPZ 550
-Lee
'84 GPZ550
'84 GPZ550
Re: caliper rebuild
24 Apr 2017 14:53
Pop out the pistons using compressed air (be careful, use a rag to contain the piston because it will shoot out with force).
Clean out all the grunge and inspect the piston. If it's rust pitted, replace it.
Install new OEM Kawasaki seals/dust boots and piston as needed. Order from your favorite OEM part source such as Partzilla. K&L brake system parts suck; the piston seals are sometimes the wrong size. Stay clear.
Lube the sliding pins using heavy black moly caliper grease.
Be sure to replace the brake lines at the same time and consider doing this same job on the master cylinder. Reusing the old brake lines is worse than reusing a condom.
- khungerf
Re: caliper rebuild
24 Apr 2017 15:04
Thanks, that is the kind of advide that is very helpful!
I will pop the piston out first and then see what I need to order. I will order the OEM rebuild kit
I have a set of SS brake lines just waiting to get installed.
-Lee
'84 GPZ550
'84 GPZ550
