- Thank you received: 47
My 1977 KZ750 Chain BROKE today while I was riding
- Shabba
JWKZ750 wrote: I have a question. Im trying to determine if this is human error that caused the chain to fail. My mechanic put new tires on the bike last week. A day later this happened. How can i be clear on what caused chain failure....him or the chain?
I'm with Ed on this: cheap chains are going to be their own ending. Perhaps the stress of the wheel removal and subsequent re-tightening of the chain put it over the top? I'd put my money on that.
-Colin
-82 GPZ750
-15 Yamaha FZ-09
-00 Suzuki TL1000S
-13 Nissan Nismo Juke
- Thank you received: 2829
It is possible that the chain was not properly adjusted, and if the proper amount of slack was allowed it would put undue stress on it. However, the chain shouldn't break. It's also possible that the master link was not attached properly or was facing the wrong way and that could cause it to fail. However, there is no way you will ever know if there was human error or not.
If you plan to keep the bike you really need to use the Kawasaki Service Manual and learn how to properly adjust the chain and perform other normal maintenance tasks. That is the only way you can be sure maintenance and repairs are done properly. Ed
- JWKZ750
- Visitor
- Thank you received: 2758
There are three bearings. The set I bought (all balls) didn't list the third one. They came as a kit and all three were in it. Be sure it has the seal as well.
- JWKZ750
- Visitor
steve
- Gordoninnc
- Thank you received: 9
I figured out a LONG time ago that all drive chains are not created equal.....and pretty much you pay for what you get.
I've made the mistake and set up my gearing incorrectly and had to go with an odd number link count and have had to use the half links. I've had two fail. Correctly adjusted, aligned and lubed.......BOTH of them were caught before the chain came apart because I kept a close eye on them. To be honest......I still have the bike and it still has a half link in the chain. The manufacture of the chain I use now rates the strength for the half link at half the rating of the chain itself. This one has lasted a couple of years and a few thousand miles. BUT, I'll get around to regearing it someday back to the even numbers and do away with the half link.
I do believe the main cause of my two failures is that the links were generic links. I finally found a chain company that matched a half link to one of their chains and that's what I'm using now. But it took awhile to find it.
The reason your chain had a half link???? Who knows??? mismatched sprockets???? or.......an attempt to get more miles out of a worn out chain ( yep, ive seen it done) ....somebody takes a link out thinking that will fix the out of adjustment condition......only to find out the chain is now to short......hmmmmmm "maybe if I add one of these". You'll probably never know.
Some of the best advise is to learn how to do your own work.......but not everyone likes working on these things.
Take care, Gordon in NC
- missionkz
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
- JWKZ750
- Visitor
For instructions on performing this extremely simple task look at page 17 at:
www.kzrider.com/modules/ServiceManuals/K...l%20KZ750%20Twin.pdf
If you are too busy to at least check the chain slack I would highly recommend not riding the bike until you can find time to do so. If you find the chain slack is not set properly I would urge you to find another mechanic or let the bike sit until you have time to perform your own maintenance. Keep in mind that when problems happen while you are riding a bike you can get very seriously injured. Ed
- JWKZ750
- Visitor
