front brake master cylinder change
- cbrianroll
16 Apr 2017 14:55
I lowered my bars so now my brake lever won't rotate down, having a hard time finding info on a good replacement. A matching clutch lever set would be ideal. Thanks.
1980 kz550ltd
Re: front brake master cylinder change
16 Apr 2017 15:05
How did you lower the bar?
- cbrianroll
16 Apr 2017 15:20
Should have worded that better...sorry. I put on drag bars. Stock one now hits fork upper.
1980 kz550ltd
- JMKZHI
17 Apr 2017 05:14 - 17 Apr 2017 05:35
You can install a mc from almost any Japanese bike with 7/8" bars & single disk brake. some don't have a mirror mount.
New aftermarket are available on eb. search kz440 or 550 master cylinder. or search a small Honda. cb350. or whatever.
KTM & Ducati models came stock w a Brembo mc. new brembo are available. but check the piston bore. 12/12.5/13mm.
Last edit: 17 Apr 2017 05:35 by JMKZHI.
17 Apr 2017 06:55
Most dual disc bikes of the KZ era used a 5/8" bore front master cylinder. Watch what master you get because many are 14mm or smaller and installing one of those will lead to a more spongy lever feel than the bike had previously.
The EX650 master cylinder has a threaded mirror lug and are readily available on ebay. They are late model so internal corrosion shouldn't be an issue either. I put one of these units on my bike and like it fine.
And don't forget to get new brake lines. Reusing 35 year old brake lines is almost as bad as recycling condoms. Rennsport is a popular line supplier if money is tight. www.rennsportautoparts.com/Default.asp
You can also make lines easily using Earl's components. This is my prefered method.
- JMKZHI
17 Apr 2017 08:02
The 550 Ltd has a single disk front brake.
- G-tron
25 Apr 2017 10:43
While we're on the subject, what replacement size master cylinder should I look at for the REAR KZ1000 brake? Keen to get something off a modern bike that I know has a lot of life left it in. Maybe R1 or GSXR etc.
Not keen on rebuilding the oem one. Hasn't failed yet so lets call it preventative modifying
Eat, Sleep, Ride
