1981 GPz550. what is the go-to replacement master?
  • chopper1963
  • chopper1963's Avatar Topic Author
21 Mar 2017 18:06
#757347
need to replace a front master on my 1981 GPZ550. The orig is of course long gone out of stock.
Is there a proven replacement that will look / work like the old Tohiko?
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
Re: 1981 GPz550. what is the go-to replacement master?
23 Mar 2017 03:38
#757450
No eBay APP ID and/or Cert ID defined in Kunena configurationDo you mean aftermarket? Perhaps, but why don't you go to Partzilla and see what other models had that MC and then hit eBay?
Here is one listed for a KZ550:
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Nessism
  • Nessism's Avatar
23 Mar 2017 04:50 - 23 Mar 2017 11:07
#757451
No eBay APP ID and/or Cert ID defined in Kunena configurationThe GPz550 use a 5/8" bore master. That ebay jobbie posted above is 14mm which is smaller.
The EX650 masters work nicely and can be found for cheap on ebay. I put one on my 750 and it's been great.
Last edit: 23 Mar 2017 11:07 by Nessism.
  • 80B4
  • 80B4's Avatar
23 Mar 2017 11:01
#757480
Stick with the OEM brake parts from Japan. I do not trust the master cylinders from China and you can forget finding levers and rebuild kits when you need them. I've been using late model EX650 and er-6n master cylinders and clutch controls on my projects for years. Ebay has hundreds of those parts, so good luck!
1980B4 1000
1978 Z1R
1978 B3 750
The following user(s) said Thank You: GPz550D1, diggerdanh
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
26 Mar 2017 08:48
#757730
I don't care how bad it runs, the brakes have to work and stop your ride. There are a lot of aftermarket brake master cylinders, and some are very cheap. I'd stay clear of the cheap ones, but that's just me. Replacing with another if the same would be my first recommendation. If you wanted to change to one with a remote master cylinder like on the more modern bikes, or one from a modern bike, just about all of them bolt to our handlebars, and companies like Goodridge can customer make hydraulic lines for you. Just because it says "fits..." doesn't mean it is a direct factory replacement.
'85 GPz550(ZX550-A2)
