GPz750 R1 wobbles under hard acceleration
- HeavenlyMachines
13 Mar 2017 05:58 - 13 Mar 2017 06:00
I took the bike for the first time in a sportsbike group ride yesterday. Under hard acceleration the bike would wobble enough to force me to back off.
I had set the rear suspension hard (#5 compression, #5 damping). The swing arm bushes etc. seems ok but I had not stripped the bike and checked individually.
Is this a known characteristic of the bike? I do notice that the frame flexes quite a bit unlike my GPZ900R.
The wobbling can be seen in this vid:
Let the good times roll...
gpzninja.blogspot.com.au
Last edit: 13 Mar 2017 06:00 by HeavenlyMachines.
Re: GPz750 R1 wobbles under hard acceleration
13 Mar 2017 06:03
You may want to check to see if the bike begins wobbling at a given speed even if not accelerating. There are quite a few things that can cause that problem including tires (which can look perfectly fine); steering stem bearings; forks that need servicing; etc. Ed
The following user(s) said Thank You: GPz550D1, HeavenlyMachines
- barney
13 Mar 2017 06:04
It kind of sounds like swingarm pivot to me .
13 Mar 2017 06:24 - 13 Mar 2017 06:25
You have to check the rear/front wheel bearings,air pressure in the tires,steering neck bearings,fork oil level,acts the
bike with different (soft/medium) rear suspension set the same? Steering damper installed?
Under hard acceleration the swing arm bushes are not in the same condition as proof by hand.
Last edit: 13 Mar 2017 06:25 by Scirocco.
- HeavenlyMachines
13 Mar 2017 20:05650ed wrote: You may want to check to see if the bike begins wobbling at a given speed even if not accelerating. There are quite a few things that can cause that problem including tires (which can look perfectly fine); steering stem bearings; forks that need servicing; etc. Ed
The bike runs fine up to about 130kph where the front starts to shudder. I suspect that the front rim is a bit crooked. But those acceleration happens well under 110kph
- HeavenlyMachines
13 Mar 2017 20:07barney wrote: It kind of sounds like swingarm pivot to me .
Scirocco wrote: You have to check the rear/front wheel bearings,air pressure in the tires,steering neck bearings,fork oil level,acts the
Thanks. It seems like I have to check everything carefully and might do this when painting the swing arm.
- Tyrell Corp
14 Mar 2017 11:12
The 750R1 is the nicest handling twin shock four about imo, although the 1100 with the longer wheelbase is a bit more stable at warp speeds.
Any of the above plus maybe tyre mismatch or defective shock dampers. Go careful here, a tankslapper can be lethal,
- GPzEric
14 Mar 2017 13:34
I remember when those things were new, and the testers were complaining about the handling, and they actually shimmed the swingarem and re-torqued the steering head.
My wife asked me if I still loved her - I said "Honey, I love you more than new carburetor boots ! "
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
(2) 1981 KZ550D1 (GPz) 1 mint, 1 under construction
1983 GS1100E
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
1983 GS1100E
