Inner Fork Tube Bushing - KZ1000K1
- freebyrd24
27 Feb 2017 08:45
Hi everyone,
I did some searching on this site, and many other parts vendors and cannot find the inner fork bushing for my 1981 KZ1000K1 LTD. It is the one that fits into the groove on the bottom of the actual fork tube. If you look in the file I attached, it is on page 1, part #25. All the parts diagrams online and even on Kawasaki's website do not show this part as existing.
Has anyone had luck finding this? Or know of the part number?
Thanks!
Thanks!
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
Sold:
- Mcdroid
- Gone Kwackers
Re: Inner Fork Tube Bushing - KZ1000K1
27 Feb 2017 11:09
I suspect it comes with the fork tube and is not available as a separate piece, This suggests that you should be searching for a used fork tube for your model...making sure, of course that it comes with the tube.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- freebyrd24
27 Feb 2017 11:34
I hope that isn't the case. It's definitely a separate split piece that is meant to come off. It's a wear item, so I hope there is something out there. Otherwise I might just put it back together as is. The only issue with it is that the teflon coating on it is worn down some. It's not too bad, but I figured I would replace it while I'm in there and replacing everything else.
Sold:
Sold:
27 Feb 2017 12:05 - 27 Feb 2017 12:10
I would measure it, then check if there are any generic/aftermarket bushings available somewhere.
From a quick google search. traxxion
Last edit: 27 Feb 2017 12:10 by martin_csr.
- spdygon
27 Feb 2017 12:10
Not available and it did come as a one piece with the bottom piece.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
27 Feb 2017 12:23freebyrd24 wrote: ............ If you look in the file I attached, it is on page 1, part #25. ..............
Just curious - what manual are those pages from? Ed
- freebyrd24
28 Feb 2017 05:14
Hi Ed, Here is the cover of the manual. Kawasaki service manual
Sold:
Sold:
28 Feb 2017 08:34
Thanks. I couldn't find a part number for that bush in any of my links. Unfortunately, it looks like Kawasaki recommends replacing the fork tube if that bush is badly damaged. I think the image below is clipped from the same manual. Ed
The following user(s) said Thank You: GPz550D1, freebyrd24
- Mcdroid
- Gone Kwackers
28 Feb 2017 13:32
Try these people...they sell fork bushings and you might get lucky.
stores.ebay.com/motorcyclepartsandspares2016/
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
28 Feb 2017 13:44 - 28 Feb 2017 13:45
Here's another place that sells fork bushings. If you can accurately measure the size they might be able to help. Ed
www.racetech.com/HTML_FILES/FMB-ForkBushings.html
Home page:
www.racetech.com/
Home page:
www.racetech.com/
Last edit: 28 Feb 2017 13:45 by 650ed.
- freebyrd24
01 Mar 2017 04:58 - 01 Mar 2017 05:00Mcdroid wrote: Try these people...they sell fork bushings and you might get lucky.
Great link there, they have quite a random selection of parts. I'll save that user. It looks like they only carried the outer bearings. Which is one that is still readily available
Sold:
Sold:
Last edit: 01 Mar 2017 05:00 by freebyrd24.
- freebyrd24
01 Mar 2017 05:01650ed wrote: Here's another place that sells fork bushings. If you can accurately measure the size they might be able to help. Ed
Home page:
www.racetech.com/
I actually sent an e-mail out to about 5 different companies, and they got back to me and asked for some measurements. I'm going to send them some info and see what they can do. More importantly how much it might cost. I'll start browsing for replacement inner tubes as well.
Thanks everyone! I'll let you know what I come up with
Sold:
Sold:
