Fork seal driver 1982 GPZ750
- Madtrout
03 Jan 2017 11:27 - 03 Jan 2017 11:27
Anyone know the inside diameter of the front fork for a 1982 GPZ750? I'm looking to buy a seal driver from MotionPro, but don't have the specs, Thanks. Mark
Last edit: 03 Jan 2017 11:27 by Madtrout.
Re: Fork seal driver 1982 GPZ750
03 Jan 2017 15:49
According to the diagrams at Partzilla, the 82 750-R1 has the same fork seals as my 81 650-CSR. The csr's upper fork tubes are 36mm. I use 1-1/2 pvc pipe & fittings to drive the seals. and place a good used seal between the new seal & driver as a protector. probably not necessary, but it's what I do.
The following user(s) said Thank You: Madtrout
- Madtrout
04 Jan 2017 04:57 - 04 Jan 2017 06:39
Thanks for the info. After upgrading the rear shocks to Hagons, I decided it was time to rebuild the front end as well. New steering bearings, wheel bearings and gold valve cartridge emulators with single rate springs. After 95,000 loyal miles, its the least I can do for the old GPZ!
Last edit: 04 Jan 2017 06:39 by Madtrout.
