Fork seals
  • Epicface803
  • Epicface803's Avatar Topic Author
Fork seals
17 Dec 2016 17:16
#750338
I need to replace my fork seals has anyone done this job them selves? Is there a spring "cartridge" or will everything come apart when I take them apart. Is there a video on the interwebs of this job?
  • martin_csr
  • martin_csr's Avatar
Re: Fork seals
18 Dec 2016 05:36 - 18 Dec 2016 08:00
#750359
There's a damper rod (inner fork cylinder) below the long fork spring. The bottom allen bolt holds the damper rod in place. Even if you have an air impact wrench, you may have to use a tool to keep the damper rod from spinning. The head of your damper rod might look just like a 12-pt socket. see 2nd-to-last pic . On my 81 650-csr it's 19mm, but yours might be bigger. I use a LH 1/2" bolt w a couple of nuts & socket extensions. some guys weld a bolt & nut to a long rod. or something like that.
Last edit: 18 Dec 2016 08:00 by martin_csr.
