1980 LTD440 WHEELS
- firec1969
1980 LTD440 WHEELS
10 Dec 2016 17:01
WANT TO CHANGE THE WHEELS TO SPOKES OR LARGER REAR RIM SIZE. I CANT FIND ANY 16 IN REAR TIRE SIZES THAT I WANT.WHAT OTHER RIMS FIT MY BIKE.THANKS
Re: 1980 LTD440 WHEELS
10 Dec 2016 18:22
I'd bet that wheels from a kz400 would fit pretty easily. There may be some useful info here--
www.kz400.com/
11 Dec 2016 05:34 - 11 Dec 2016 05:41
SOME OF THE KZ305 CSR MODELS HAD SPOKE WHEELS. 19" FR AND 16" RR. NO IDEA HOW THEY'D WORK ON A 440. THE 440 STANDARD MODELS HAD AN 18 RR.
Last edit: 11 Dec 2016 05:41 by martin_csr.
- firec1969
12 Dec 2016 03:57
thanks ,I'm building a scrambler and no-one makes 16 endure tires i like.18in has more choices
12 Dec 2016 06:06 - 12 Dec 2016 06:24
From partzilla the 82 G1 is the only 440 model I saw with an 18" Rr cast alloy wheel. It's belt-drive, but you should be able to swap a sprocket carrier no problem. I saw two of them listed on eebbaayy.
The 80-81 440-B wheels are spoked w 18" Rr & they are probably the same as the KZ400.
Last edit: 12 Dec 2016 06:24 by martin_csr.
