KZ700 swingers bearing upgrade
  • Jekyll86
  • Jekyll86's Avatar Topic Author
07 Dec 2016 16:05
#749733
hello Gents!
I've searched the site to see if I can find what bearings I will need to replace the sleeve-type swingarm pivot on my KZ 700. Unfortunately, most information I find is in the form of links to other sites which are either dead or for different sized bikes, such as the 900 or 1000. The only bearing kits I have found are for the larger bikes.
So... 2 questions.
1) Are any other KZ swingarms the same dimensions as the KZ700?
2) Will the 900 bearing kit fit on the 700/750s?
1984 KZ700A1 Franken-saki 810 kit
1976 KZ400 broken-saki
1981 KZ750B
2018 z900rs
  • Nessism
  • Nessism's Avatar
Re: KZ700 swingers bearing upgrade
07 Dec 2016 17:23
#749735
The KZ700-A1 parts fishe shows that the swingarm pivot bearings are needle bearings. What exact model year bike do you have?
07 Dec 2016 17:52 - 07 Dec 2016 17:54
#749741
Nessism wrote: The KZ700-A1 parts fishe shows that the swingarm pivot bearings are needle bearings. What exact model year bike do you have?
Exactly (See www.powersportswarehouse.com/p/Kawasaki#...00-A1-1984/080199E-6 ) . Have you looked inside the swingarm yet to see what's in there? Ed
Last edit: 07 Dec 2016 17:54 by 650ed.
  • RonKZ650
  • RonKZ650's Avatar
07 Dec 2016 18:41
#749742
Yea, they went to tapered needle bearings in 1978. No way the KZ700 has sleeve bearings.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
08 Dec 2016 06:40
#749761
To answer your question...KZ900 bearings will not work. Bearings from many of the 1982/1983 KZ750(4) models will work...part number (or equivalent) 92046-1115.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
The following user(s) said Thank You: Jekyll86
  • Jekyll86
31 Aug 2019 12:21
#810153
Thanks Everyone. Mcdroid - Good info!
Still haven't touched the bike :( Life got in the way but hopefully getting this thing moving again soon.
1981 KZ750B
2018 z900rs
