95 GSXR 1100 or 98 GSXR 750 - fork/swingarm swap??
- BOOM_FIST
30 Nov 2016 13:26
I have the option of getting 1 of 2 separate bikes for fairly cheap.
First, 95 GSXR 1100 roller:
- 1995 Titled Roller. This means a frame, wheels, tires, front end, swing arm. A rolling chassis.
- Untitled drag frame. Clean, undertray, ready to build.
- 1 rack of Mikuni BST36 flatslides.
- 2 Headlight Assy.
- Various engine parts (some odds and ends.)
- 2 Gauge Clusters.
- Airbox
- Various plastics /Fairings
- 2 Fuel tanks
- Misc parts, Shocks, Grab rail, hardware, cooling fan.
- 2 Exhaust Headers
Second, 98 GSXR 750 complete bike that apparently just needs coil packs?? His ad:
I have a 1998 suzuki gsxr 750. I have everything for the bike. I have it taken apart right now because i had to put new starter on it. And it needs coil packs and that's it. The fairings are primered and ready for paint. The bike had 55k miles. Changed oil every 3000 miles. The bike ran excellent before starter went out. All you need is coil packs and your riding.
Out of these 2 ads, which would be a better choice for a fork and swingarm swap? My hopes are that I can complete my desired look with either one of these bikes, but out of the 2, don't know which would be easier/better to swap. Everything else I would part out and recoup some cash...maybe even profit some.
I did have a bead on a complete 94 ZX9R, but it sold before I got to him.
Give me your opinions and thoughts please. Any measurements and dimensions of the forks and swingarm would be helpful as well. Or if anyone has used these exact parts to do their swap.
Thanks
- 2 Headlight Assy.
- 2 Gauge Clusters.
- Airbox
- 2 Fuel tanks
- 2 Exhaust Headers
Thanks
1977 KZ900A5
- davido
Re: 95 GSXR 1100 or 98 GSXR 750 - fork/swingarm swap??
30 Nov 2016 23:16
Id go for the one with the longest forks.Not sure which one that is though ( I think the ZX9Rs have the longest USDs) There is a list somewhere with the various fork lengths. I had it but cant find it.Someone else here must have it or a link to it. Not sure if either swingarm is going to fit in a Z. I do know a GSXR600 swingarm will fit as thats what I put in mine.Have a look through the various project threads. Good luck.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
01 Dec 2016 06:11
i'm thinking the 95 1100 is going to be the quicker easier fit.
depending on how much your willing to mod your frame you may have to cut the hoop off the top of the arm.you can leave it off or weld a new one on the bottom.
what bike are you planning to hang these pieces on?
- BOOM_FIST
01 Dec 2016 12:21 - 01 Dec 2016 12:21davido wrote: Id go for the one with the longest forks.Not sure which one that is though ( I think the ZX9Rs have the longest USDs) There is a list somewhere with the various fork lengths. I had it but cant find it.Someone else here must have it or a link to it. Not sure if either swingarm is going to fit in a Z. I do know a GSXR600 swingarm will fit as thats what I put in mine.Have a look through the various project threads. Good luck.
I couldn't find anything on these particular bikes either. I think I came across that list as well, but it didn't help any for these 2 bikes.
531blackbanshee wrote: i'm thinking the 95 1100 is going to be the quicker easier fit.
These are going on my KZ900A5...in my signature. I was more leaning towards the 98 750 ONLY because worst case I replace the parts that it needs to get running and flip it for a profit then keep searching for another ZX9. I definitely don't want to completely waste my time either if none of these are great candidates.
Hoping more might chime in with more specifics on these 2 bikes....
1977 KZ900A5
Last edit: 01 Dec 2016 12:21 by BOOM_FIST.
- 750 R1
01 Dec 2016 13:53
The 1100's generally have longer forks, so I'd go for that if you wish to retain ground clearance. Are you building this bike to improve handling or just for looks..? I ask because the swingarm will be around 4 inches longer than stock, whilst it may look good, it won't improve handling.... To do the front properly you may need to look at new triple clamps too, the offset will be different which will alter trail and also effect handling... If you are aware of all this just ignore my comment...
PS, I think your bike looks great as it is....
The following user(s) said Thank You: BOOM_FIST
- BOOM_FIST
10 Dec 2016 14:53
Thanks 750 R1!
It's more for looks...but handling as well. With modern brakes, tires, and suspension I would imagine all these aspects would improve.
After some more research, I've come across the GSX Katana as a good option to use for a front and rear swap as well. And one can find these fairly cheap pretty much everywhere.
1977 KZ900A5
- spdygon
11 Dec 2016 15:22
1100 forks are longer....im using the 93 1100 . As the rear goes I don't like them...2-3 longer.
All balls bearing has a bearing kit for a direct swap or you can swap stems.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
- BOOM_FIST
11 Dec 2016 16:01spdygon wrote: 1100 forks are longer....im using the 93 1100 . As the rear goes I don't like them...2-3 longer.
Thanks spdygon!
So, out of the 2 bikes...the 1100 forks are longer. What's the length difference of the 1100 to my stock forks? Still shorter? By how much?
You used the swingarm too? I don't mind 2"-3" longer, but what about the pivot width? Thanks man!
1977 KZ900A5
- kaw-a-holic
11 Dec 2016 22:02Still shorter by about an inch. Don't forget that if you use modern 17" wheels you loose height there also. My 77 had a 19" stock front so I lost an inch of clearance in just the wheel swap. The other issue you will have is the turning radius will be gone if you use the GSXR triple. After trying just a bearing swap I opted to make a custom drop triple that allows me to use the KZ stem and get close to the same offset as stock.BOOM_FIST wrote:spdygon wrote: 1100 forks are longer....im using the 93 1100 . As the rear goes I don't like them...2-3 longer.
Thanks spdygon!
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- BOOM_FIST
12 Dec 2016 14:11
Thanks Jon, I'm hoping to make a decision on which parts bike I want to go with. I've been told the early 90's Katanas are a good candidate as well. So between the 1100 and the Katana, I'm sure I can find one for dirt cheap and start swapping.
Thanks everyone!
Thanks everyone!
1977 KZ900A5
- kaw-a-holic
12 Dec 2016 18:46I found my 1100 front end by posting on a GSXR Facebook forum. Got it for cheap.BOOM_FIST wrote: Thanks Jon, I'm hoping to make a decision on which parts bike I want to go with. I've been told the early 90's Katanas are a good candidate as well. So between the 1100 and the Katana, I'm sure I can find one for dirt cheap and start swapping.
Thanks everyone!
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
- btchalice
29 Dec 2016 13:20
i have the 750 forks on mine the 1100 would be a better choice i think they are 1 to 1.5 inches longer
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
