Rear swing arm conversion
  • rmwsh
  • rmwsh's Avatar Topic Author
25 Nov 2016 11:42
#748894
Hello i am new to this forum
Has anyone done a conversion , with a 2007 zx6 rear swing arm on a 1975 kz 900.
What needs to be done to make it fit
Thanks
  • 750 R1
  • 750 R1's Avatar
Re: Rear swing arm conversion
25 Nov 2016 12:58
#748896
rmwsh wrote: Hello i am new to this forum
Thanks
Explain what you are trying to achieve and you'll probably get a far more reasoned response... ;)
  • TexasKZ
  • TexasKZ's Avatar
25 Nov 2016 14:21
#748904
Welcome to KZR.
Several members here are running a mono shock swingarm on an early Z frame. Have you searched the forum for these discussion threads? You will find that a good deal of fabrication and very careful planning are needed.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
25 Nov 2016 20:12
#748933
If you follow this link and explore the threads in it you'll likely get your answer.
www.kzrider.com/forum/search?query=mono%...ildforums=1&start=20
Good Luck
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
