Aftermarket rearsets
  • rokit_armor
  • rokit_armor's Avatar Topic Author
23 Nov 2016 20:45
#748801
Hey Guys! I'm looking for a set of rearsets for the KZ1100a2 that are much sportier than stock. I had seen somewhere, a set of R6 rearsets on an A2 shaftie, but I think the set I ordered may be the later generation. The set I ordered is for the '06-'15 model, which has the vertical shift. I'm not looking for Tarozzi style rearsets, I'm putting a very aggressive ride stance on this bike. It looks like perhaps a '04/'05 ZX10R rearset would work? I understand I would have to make the brackets to mount them to the frame properly, I'm mostly concerned with the shift linkage.
Also, does the, agh terminology is failing me, the doo-hickey with the splines that the linkage connects to, would the zx10 one fit?
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Aftermarket rearsets
24 Nov 2016 06:31
#748819
Or you could ask Les Holt ( a member here ) to just build you a set like he has done for me and other members
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
24 Nov 2016 06:56
#748824
I am using a set of Tarozzi Universal rearsets from www.fastfromthepast.com/ They offer the folding type, and fixed. I have been using the fixed set for many years.
'85 GPz550(ZX550-A2)
  • davido
  • davido's Avatar
24 Nov 2016 07:35 - 24 Nov 2016 11:38
#748828
I have a set of early CBR600 ( I think). Cheap and cheerful. I made the adapter plates from 10mm aluminium just using regular woodwork tools. That was pretty straightforward. The problem I had was finding the right position. First time round the brake lever hit the exhaust.I raised them up then my knees were touching the corners of the engine. Ilowered and moved them back,cut and rewelded the brake
lever then the side stand was hitting on the gearshift. I got it sorted in the end and they sit well now and dont foul on anything butit was a big headache.
As far as I know the spline on the end of the gearshift is a universal size.
P.S. Just remembered,I have to loosen the righthand rearset to get the battery out!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Last edit: 24 Nov 2016 11:38 by davido.
  • rokit_armor
24 Nov 2016 22:05 - 24 Nov 2016 22:11
#748868
Thanks for the feedback guys!
StreetFighter, your turbo'd monster makes me drool every time, and those rearsets are sexy as all get out, but they're just not the style i'm looking for. Les does some dang good work, and I'll employ his talent when I'm building a bike that fits the style. Those are just to simple for me, same with the Tarozzi rearsets. They look great, but just not what I'm going for with this bike- ultra-modern (picture an 80's cyberpunk anime)
davido, i took a peek at the CBR600(ish?) rearsets. while cheap and filled a few check marks, didn't quite cover the gambit. Also, pics or it didn't happen XD
(edit) davido I just speed-read your build thread, Some great info from your build, as well as the other members chiming in on their rearsets, Thanks!
Ended up ordering this ZX10R rearset as well.
Last edit: 24 Nov 2016 22:11 by rokit_armor.
  • Tyrell Corp
  • Tyrell Corp's Avatar
26 Nov 2016 08:36
#748974
You may have issues with the side-stand fouling the re-positioned gearlever, also if you are changing the wheels this will affect the ideal sidestand length too. Best to be aware of this early on in the build.
I got lucky on my 750 and used a slightly longer stand from a 1000. Re positioning the stand frame mount is another option.
  • baldy110
  • baldy110's Avatar
28 Nov 2016 14:23
#749117
These rearsets came off a 1997 Yamaha FZR1000. I fabbed up some plates and custom control rods then stuck them on my ELR clone, Cost was $100.00.
[IMG
[IMG
[IMG
[IMG
  • spdygon
  • spdygon's Avatar
03 Dec 2016 09:54
#749353
baldy110
did your bike sell?
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • baldy110
  • baldy110's Avatar
05 Dec 2016 08:53
#749527
Yes it did. To someone out of the Bay area.
  • spdygon
  • spdygon's Avatar
06 Dec 2016 18:14
#749686
Congrats....super build you had
1974 Z1 900 project
  • rokit_armor
20 Jan 2017 01:42
#752520
Well the ZX10R rearsets worked out well. Going to have to move the kickstand forward a bit but that's OK.
  • rokit_armor
20 Jan 2017 01:45
#752521
Yeh. Just a bit too close haha.
