- Thank you received: 4
whats the difference between these seats?
- janecek
Attachment IMG_0907.JPG not found
- Thank you received: 2738
- Thank you received: 1656
And the pan may have a different shape as the B-model frame seems to be flatter than the later K-models.
- janecek
swest wrote: It may have to do with the placement of the hinges and seat lock. Pics of the two?
I'm ok with changing the location of hardware. anybody have a picture of a 77-80 LTD frame?
80 KAWASAKI KZ1000 KZ 1000 LTD FRAME CHASSIS
KZ1000 LTD KZ1000B Vintage Used Seat
- janecek
thanks for the information. looks close enough for me. I will post the results to let everyone know how it went.martin_csr wrote: The hinge location is similar.
- mopguy
- Thank you received: 168
- janecek
- Saablord
- Thank you received: 66
The csr seat is approx 30"L x 12.5"W. ... width was measured at about the middle, at the 5th seam where the seat is widest. see pic.
1982 KZ750-H3 Ltd seat. It's identical to the 650-CSR I measured. the H3 seat is on my motorcycle. they're identical.
* - the 1980 750-H1 has an unusual 2-piece seat.
- Thank you received: 2301
The frame rails on the "J" series bikes (81 on) are wider apart than the earlier 1000 so hinge and catch positions would need some work (duckbill needs to be widened to fit the later frame)Bit of an old thread, but no point in starting a duplicate. I also have a 82 1000 LTD and am looking at seat options. Can anyone else confirm, or provide more details on, if the smaller four LTD seats swap (with some minor tinkering...moving pivot points it sounds like) to the 1000 LTD? Does "fit" mean the lock catch and other bits need to be adapted as well?
