Boge Mulholland Shocks
- missionkz
30 Oct 2016 13:33 - 30 Oct 2016 13:41
Not sure what to do with these.
13" with standard springs. I woukd assume 120 lb or close as I was only around 135lbs back then! LOL
I think I had these on one of my old Triumph cafe bikes...35 or maybe more years ago.
Are they rebuildable or worth anything to anyone?
www.thejunkmanadv.com/boge-mulholland-shocks-info.html
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 30 Oct 2016 13:41 by missionkz.
- slmjim+Z1BEBE
Re: Boge Mulholland Shocks
30 Oct 2016 16:10
PM sent.
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- Mcdroid
- Gone Kwackers
30 Oct 2016 23:17 - 30 Oct 2016 23:18
Well, what did SlmJim say? I also had a pair that I didn't know what to do with (one was leaking) and I ended up tossing them.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 30 Oct 2016 23:18 by Mcdroid.
- Kidkawie
- I bleed premix
31 Oct 2016 05:27
Check out Marks Swapmeet for parts/sources.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- barney
31 Oct 2016 05:36
Well they definitely look rebuildable I'm not sure they are worth the effort though. No offence.Unless you have an attachment to them(which it sounds you do). Works Performance in California will rebuild any shock if possible. They actually offer this service to all brands as long as they have similar rebuild parts or can machine something to work. I think Race Tech also offers rebuild service too
Barney
Barney
- missionkz
31 Oct 2016 20:47At 13.0 inches, I think they are too short for my KZ1000 and two up riding.barney wrote: Well they definitely look rebuildable I'm not sure they are worth the effort though. No offence.Unless you have an attachment to them(which it sounds you do). Works Performance in California will rebuild any shock if possible. They actually offer this service to all brands as long as they have similar rebuild parts or can machine something to work. I think Race Tech also offers rebuild service too
Barney
Besides my current shocks seem good now with only about 20,000 miles on them
I just didn't know for sure if anyone rebuilds these and or are they worth recycling on a bike refurb.
Bruce
1977 KZ1000A1
1977 KZ1000A1
- loudhvx
01 Nov 2016 18:43
If the shocks leak, toss them, but either way, keep the springs. Many new shocks require springs purchased separately. I find the old springs, even stock ones, can be made to fit new shock bodies.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Kawboy74
05 Nov 2016 19:16
Those shocks are likely from an LTD model '76-'80 anyway.
David
David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
- missionkz
06 Nov 2016 16:32 - 06 Nov 2016 16:39
Although I am not sure LTD shocks were all Mulholland, don't think the shocks on LTDs were rebuildable.
These not so clearly, have a large nut on the shaft, under a the springs of the valve body.
Bruce
1977 KZ1000A1
1977 KZ1000A1
Last edit: 06 Nov 2016 16:39 by missionkz.
The following user(s) said Thank You: seanbarney41
- jeffz
02 Oct 2017 10:35
I have them on my Z1R. 13.75 in. with the preload all the way up. Does that change if you release the preload?
Loudhvx, thanks. I never thought of re-using the springs. I just want to disassemble mine to repaint the springs. Maybe someone can chime in if they have done it.
Thanks!
Thanks!
