Question about fork gaiters and floorboards.
- newjack213
23 Oct 2016 16:30
I am about to replace the fork seals on my 79 KZ1000ST and while everything is apart I wanted to add fork gaiters. I like the way they look with the Vetter fairing. I know several of the Police models came with fork gaiters and was wondering which year model I should look at for a direct swap? I'd also like to add floorboards and a heel toe shifter from a Police model as well and was wondering if there would be a year range to look at for a direct fitment or if some fabricating might be necessary?
Any ideas or nudges in the right direction will be greatly appreciated!
Re: Question about fork gaiters and floorboards.
24 Oct 2016 05:57 - 24 Oct 2016 06:30
Fork gaiters. From the ohio cafe racers fork tube size conversion chart the 1000E fork tubes are 40mm, but the 1000C & P police models are 38mm, as are the 1100D Spectre & I think the 1100 Ltd Shaft are also 38mm.
Assuming the above sizes are correct, you'd need gaiters that are 40mm ID at the top & then you'd need to measure your fork lowers to figure out the bottom ID. Note: some riders don't like fork gaiters as they can trap moisture.
Floorboards. I really don't know, but maybe the stuff from the 78-81 KZ1000-C police models as the floorboard brackets are bolted to the frame. The later 82-2005 1000P models have the floorboard mounting brackets welded-on as part of the frame. From the cross-refrence at Partzilla, all of the police bikes have the same floorboard step assys.
Last edit: 24 Oct 2016 06:30 by martin_csr.
The following user(s) said Thank You: newjack213
