Z1 Seat Stuck
- Yorkie
Z1 Seat Stuck
17 Oct 2016 19:12
Help! The seat on my Z1 is stuck shut. I have tried to drive out the pivot pins but they are frozen in there. Any tricks you know of to pop he latch? The bike is a '73 if that helps
'72 Z1
- slmjim+Z1BEBE
Re: Z1 Seat Stuck
17 Oct 2016 20:05
Can we assume the latch lever rotates fully 90 degrees? On one of ours the latch won't release if the key is in the seat lock. The head of the key keeps the latch lever from traveling far enough to release the latch.
Unless they have been removed, the hinge pins have cotter pins in them that would keep the pins from being driven out.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- Yorkie
Re: Z1 Seat Stuck
18 Oct 2016 06:35
The lever needs to be pointing downwards to allow the seat to release, correct?
'72 Z1
- MDZ1rider
Re: Z1 Seat Stuck
18 Oct 2016 09:12
Typically it would be pointing down to release, but I've seen bent levers. It needs to rotate 90 degrees clockwise from the starting (home) position.
- Yorkie
Re: Z1 Seat Stuck
19 Oct 2016 07:01
Popped it. You can push on the catch by reaching through to frame opposite to the latch assembly. The nut had come off the end of the lever. Put a new one on and it's fixed.
'72 Z1
