Model Comparison--KZ 550
- Stosho
- Stosho
29 Sep 2016 04:33
What are the critical differences between the KZ 550 and the GPz in 1982? The stance of the bike looks significantly different. Was that due to the frame, wheels, or something else. I ask only because there is a possibility of getting into a project with the KZ and I was wondering if for all practical purposes that could be changed to the GPz look.
Stosho
1978 KZ 650 B (x2)
1976 KZ400 AHRMA Racer
1966 Honda Cub
1978 KZ 650 B (x2)
1966 Honda Cub
- Tyrell Corp
Re: Model Comparison--KZ 550
29 Sep 2016 04:55
The 82 model year has unitrack monoshock, a longer wheelbase, 35mm forks and -dare I say it, 5 spoke wheels.
The twin shock kz gpz models are all pretty similar.
- Stosho
- Stosho
29 Sep 2016 18:44Tyrell Corp wrote: The 82 model year has unitrack monoshock, a longer wheelbase, 35mm forks and -dare I say it, 5 spoke wheels.
Thanks. So as I understand it the frames are essentially the same.
Stosho
1978 KZ 650 B (x2)
1966 Honda Cub
1978 KZ 650 B (x2)
1966 Honda Cub
- loudhvx
30 Sep 2016 07:13 - 30 Sep 2016 07:16
The Kz550A (standard) frame is quite different from the 82-83 Kz550H gpz. Obviously the rear suspension is different. All of the body work is different. The tank is different. The footpeg mounts are different. The wheel base is different. The forks are different. The battery box area is different. The fork clamps are different. All of those differences require differences in the frame. I'm not sure there is any part of the frame that is the same except maybe the backbone and engine cradle.
Now, the Kz550A (standard) frame, as Tyrell said, is almost exactly the same as the 81 Kz550D1 gpz, but the 82 is different.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 30 Sep 2016 07:16 by loudhvx.
