Front rim from Z1 Enterprise
- tomsbadkz
Re: Front rim from Z1 Enterprise
21 Sep 2016 14:24
The bike Im doing now is going to run 9"s. I learned alot from the other bike. It has a regular KZ head with some work on a big 1385 motor. Dont think it was breathing very well for the motor size. My new motor is a 1327 with coated MTC 10.5 to 1 pistons, A bathtub GPZ1100/ZN1100 head that LarryC did for me. 38.6 intakes, 33 exhaust valves. Web Cams .436/.465, Star titanium retainers, Kibblewhite springs and it flows over 100cfm. Falicon 16 tooth KZ crank with a set of brand new 38mm Mikuni's. With the 300 tire, traction shouldn't be too much of an issue. Im also considering NX nitrous just for a small kick in the butt occasionally.
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
- Kray-Z
- I need more power Scotty....
21 Sep 2016 14:52Kapahulu wrote:That's a great point. Crash a newer bike and it might be toast, rims and frame. Older bikes were overbuilt and way heavier. But when they get in minor crashes sometimes the damage is minor. A few years ago a car turned in front of me riding my KH400. Besides a small bone in my foot, the only things bent/broken were the headlight ears and the brake lever.Kray-Z wrote: As an aside, look at how minimal, fragile, and weak the 3 hollow spoke "spiral" cast front wheel of a new GSXR1000 looks.....then think of it's 180 mph top speed potential....stock! Unbelievable!
Yes - new alloy framed race replica style sport bikes break frames, wheels, and forks with even minor collisions. Seeing a Ninja600R break in two at a 40 mph impact is a sobering eye opener....
I'm planning on using wheels from one of those new GSXR's on my KZ1170 Beater II, but I can tell you I'm more than just a little worried about how the front will survive a hard landing from a wheelie or a pot hole.....
- Kray-Z
21 Sep 2016 15:00tomsbadkz wrote: The bike Im doing now is going to run 9"s. I learned alot from the other bike. It has a regular KZ head with some work on a big 1385 motor. Dont think it was breathing very well for the motor size. My new motor is a 1327 with coated MTC 10.5 to 1 pistons, A bathtub GPZ1100/ZN1100 head that LarryC did for me. 38.6 intakes, 33 exhaust valves. Web Cams .436/.465, Star titanium retainers, Kibblewhite springs and it flows over 100cfm. Falicon 16 tooth KZ crank with a set of brand new 38mm Mikuni's. With the 300 tire, traction shouldn't be too much of an issue. Im also considering NX nitrous just for a small kick in the butt occasionally.
Hey, we should compare our builds and track results when finished! :woohoo:
Two on the way - mine and jberger635's are similar 1394 MTC, mine is a Cavanaugh Racing dual plug J head with same cams and valves as yours, jbergers's is a mild GPz bathtub with stock valves and APE 410's, but injected / managed....
kzrider.com/forum/11-projects/602248-the...injected-monstrosity
