530 Chain conversion
- 750 R1
Re: Re:530 Chain conversion
10 Sep 2016 15:59
Anyone know the exact width at the spline of the stock 630 front sprocket...?
- Nebr_Rex
Re: 530 Chain conversion
10 Sep 2016 20:01
Just order/buy the sprockets and chain for a '78 KZ650.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- 750 R1
11 Sep 2016 16:26Nebr_Rex wrote: Just order/buy the sprockets and chain for a '78 KZ650.
I'm going with the 520 conversion, the 650 rear sprocket has a 74mm diameter center hole, the Kz 750 has an 80mm center, don't know if they would fit anyway....
11 Sep 2016 16:54 - 11 Sep 2016 16:54
The 520 sprockets are narrower. You may need a sprocket spacer. :silly:
Last edit: 11 Sep 2016 16:54 by Nessism.
- 750 R1
11 Sep 2016 17:12Nessism wrote: The 520 sprockets are narrower. You may need a sprocket spacer. :silly:
Yep, I'm all over it, the 520 front I've ordered has an 8.5mm center boss, once I get them in my hand I can measure everything and sort it all out..
- 750 R1
16 Sep 2016 18:24 - 16 Sep 2016 18:37
Well the 520 sprockets arrived, I also ordered a EK heavy duty 520 chain. I pulled the sprocket cover off and removed the stock 630 chain and sprockets, to my surprise, the center of the ZXR400 front sprocket is the same width as the 630, no spacers needed, the 17 inch front sprocket is a tight fit but theres just enough room, this will be the easiest conversion ever... The bad news is that I found the bottom rear engine mount bolt had been broken and never replaced , its actually still in the frame but the left side end has been snapped off and just left, the engine has dropped a little on the mount , top mount bolt has a small bow in it, so i'll need a new bolt, nut and washer before it all goes back together, glad i found that... Also, the front sprocket retaining washer was fitted correctly but the sprocket nut was loose...!! Why are people so slap happy when working on anything mechanical...? Anyway, these are all easy fixes, just got to wait for some more parts....
Its quite hard to see exactly what i need on the parts fiche, can someone confirm I'm getting the right parts please...? The parts are 92001B and 92015... Thanks
www.partzilla.com/parts/search/Kawasaki/...+FITTINGS/parts.html
Last edit: 16 Sep 2016 18:37 by 750 R1.
- 750 R1
17 Sep 2016 20:28750 R1 wrote: Well the 520 sprockets arrived, I also ordered a EK heavy duty 520 chain. I pulled the sprocket cover
Can anyone please confirm re lower rear engine mount...?
- scubaanders
18 Sep 2016 11:58
Hard to tell, but the 92001-1622 engine mount bolt is a M10x225.
What i assume is the lower bolt 92001-1623 is a M10x250.
At least according to cmsnl and Partzilla
/A
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
The following user(s) said Thank You: 750 R1
- 750 R1
18 Sep 2016 15:11
Thanks Anders, I'll have to measure the length, its bloody hard to tell from the Parts fiche...
- 750 R1
20 Sep 2016 23:40
Well I ordered both rear mount bolts, the top one had been carrying all the weight and had bent.
