Wheel bearing question
  • Bigmd
  • Bigmd's Avatar Topic Author
05 Sep 2016 08:22
#741171
Maybe someone can help me. I'm converting my 79KZ650 to mag wheels. I researched and found out that a 1980 KZ 550 16" rim will work. Ii had bearings taken out so I can have rim powdered . The bearings are both the same size. When I go to all balls site they list two different KZ models. One model has two bearings but they are different sizes. The other has 3 bearings. So I'm confused and not sure I have right wheel. Can someone help?
  • Bigmd
Re: Wheel bearing question
05 Sep 2016 08:44
#741173
Ok just want to add that I had a shop remove the bearings. I'm looking at rim and he gave me back the two bearings that fit on the outside. Im assuming there's a 3rd bearing that the goes in the middle that the spacer goes through? Does that sound right? Otherwise the spacer has no way to fit inside the hub.
  • martin_csr
  • martin_csr's Avatar
05 Sep 2016 09:21 - 05 Sep 2016 09:22
#741176
Yes, the rear wheel has a large carrier bearing. You can check stuff like this at Partzilla.
Is the bike a 650B?
Last edit: 05 Sep 2016 09:22 by martin_csr.
  • Bigmd
05 Sep 2016 09:27
#741178
I'm not sure haha. Bought off CL . How do I know if it's a B? Anyway I think I found my answer to bearing question. The larger bearing goes in the hub coupling.
  • martin_csr
05 Sep 2016 11:30
#741205
The 650B has wire spoked wheels. single disk front brake & 18" Rr w drum brake.
sprocket carrier is an alternate term for the hub coupling.
Model identification. jarlef z650 .
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Sep 2016 11:31 - 05 Sep 2016 11:31
#741206
The third bearing goes in the sprocket hub. They should all come in the kit.
Last edit: 05 Sep 2016 11:31 by SWest.
05 Sep 2016 15:36
#741224
Bigmd wrote: I'm not sure haha. Bought off CL . How do I know if it's a B? Anyway I think I found my answer to bearing question. The larger bearing goes in the hub coupling.
Easy - just look at the VIN that is stamped into the steering neck. If the VIN starts with KZ650B it's a B model. Ed
