KZ 75e forks
  • Outacontrol
  • Outacontrol's Avatar Topic Author
KZ 75e forks
02 Sep 2016 05:12
#740858
Hey......
Pulling down KZ 750e 36mm forks......question ????
Is the allen bolt on bottom of fork leg right hand thread or left ?
Seen some stuff saying its left but want to know for sure...
Cheers
  • martin_csr
  • martin_csr's Avatar
Re: KZ 75e forks
02 Sep 2016 05:29
#740859
It's RH. be sure to use a brake caliper socket or hardened socket. in case it's a bear to get out.
  • Nessism
  • Nessism's Avatar
  • Away
Re: KZ 75e forks
02 Sep 2016 07:44 - 02 Sep 2016 07:46
#740887
You may have to use a tool of some sort to hold the damper rod inside the fork from turning while you crank on the allen head screw on the bottom.
I use a spark plug socket that has a hex pattern on the outside and stick a long extension in the socket backwards. The hex matches perfectly with the hex inside the damper rod so you can hold it stable. Other guys make a tool from a bolt and/or a piece of threaded rod.
Last edit: 02 Sep 2016 07:46 by Nessism.
  • Outacontrol
Re: KZ 75e forks
02 Sep 2016 18:55
#740956
Thanks for the help and advice guys.
