75' KZ400 D3, Front Brake Adjustment (Drum)
  • DannyKZ
  • DannyKZ's Avatar Topic Author
  • 2 KZ400's
01 Sep 2016 13:27
#740798
Hey guys,
I'm running into a bit of an issue adjusting my front brake drum. I can get either the rear, or front pad to grab, but not both. I've fiddled with the connecting rod a bunch, and also with the main cable adjustment on the drum and the handle-bar adjuster... regardless of the settings, I can pull the lever back to the bars and only have minimal biting force.
I did remove the linked levers to paint the drum... and re-installed to how they were removed.
My only guess is that I installed the levers incorrectly on the splines... Here's a picture of how it's installed now. I have gone through the manual and it is VERY LIMITED as to how it says to adjust everything, and hardly any procedure or specifics on re-installing the levers.
Any ideas?
Attachment 20160830_093748-2.jpg not found
Life's a tour, not a race. Just stay out of my way when I'm touring.
  • DannyKZ
  • 2 KZ400's
Re: 75' KZ400 D3, Front Brake Adjustment (Drum)
01 Sep 2016 13:35
#740801
I actually found a picture of the original setup... I think I'm about 2 teeth off on the splines on BOTH cams... Granted, it's skewed a bit from the angle, but you can clearly see the connecting rod is at the wrong pitch...
Attachment OldWheel.JPG not found
