wire spoke wheel tubeless
- gpz1170
01 Sep 2016 09:58
thinking of running a wire spoke wheel tubeless. any suggestions ?
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
Re: wire spoke wheel tubeless
01 Sep 2016 10:01
Yes - don't do it. It's perfectly normal; to run tubes inside tubeless tires, so that's what you should do. If you try running with no tubes on wire wheels that were made for tubes you run a very high risk of loosing air, and it could happen at a most inopportune time. Ed
- baldy110
01 Sep 2016 12:55
You can get it to work, I have cleaned the spoke nipples really good and apply silicone sealing them. I had rims last for decades doing this. Or if you really want the bomb, try these guys
www.woodyswheelworks.com/
they have been sealing spoked rims to run with tubless tires for years.
01 Sep 2016 13:08
Or you could convert to some modern spoked rims like BMW uses that are designed for tubeless from the get go.
- gpz1170
01 Sep 2016 16:35
have heard that there are rim and spokes combos now that are designed to run tubeless. I have a bad habit of ripping valve stems.
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
01 Sep 2016 16:47gpz1170 wrote: have heard that there are rim and spokes combos now that are designed to run tubeless. I have a bad habit of ripping valve stems.
don
Been there on my BSA - not fun! My KZ650-C1 has rim locks on the rear wheel to prevent that from happening. Does your rear wheel have the 2 extra holes for rim locks? Ed
- gpz1170
04 Sep 2016 05:56
haven't bought anything yet, exploring options
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
