Fork id
- Paulzaplitny
Fork id
30 Aug 2016 09:59
I have a 71 cb 750 chopper that I need to rebuild the forks on. They appear to be from a kz. Was hoping someone here could help I'd them.
- StreetfighterKz
Re: Fork id
30 Aug 2016 10:07
We probably can but I do not see a pic in your post?
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Paulzaplitny
Re: Fork id
30 Aug 2016 10:27
Looks like the wheel is backwards. What is the OD?
- Paulzaplitny
Re: Fork id
30 Aug 2016 10:31
Yes. Looks like a KZ hub. Four bolt?
- Paulzaplitny
Re: Fork id
30 Aug 2016 10:39
Digital micrometer was reading 36.81 mm on the tube and 6 bolts bolt the rotor to the hub if that's what you're referring to.
- Nerdy
Re: Fork id
30 Aug 2016 10:41
Unrelated, but it looks like cylinder #2 might be running rather lean (unless there was a variance in the plating when the headers were made). #1 might be as well but it's not clear. #3 and #4 look good.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Re: Fork id
30 Aug 2016 10:48Paulzaplitny wrote: Digital micrometer was reading 36.81 mm on the tube and 6 bolts bolt the rotor to the hub if that's what you're referring to.
I don't think that's a KZ front end. Are you sure it's 6 bolt? The rotors look like mine but not the sliders.
- StreetfighterKz
Re: Fork id
30 Aug 2016 10:55
First thought I had when I saw the pic was a HD front end with a 21" wheel. The fender and the way it mounts looks like something from a Sportster perhaps?
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Paulzaplitny
Re: Fork id
30 Aug 2016 11:04
AMF?
