Ninja 900 gpz rear tyre question
- shamal
24 Aug 2016 04:27
Hi all. I just need to know if a zx900a (first series) can take a 160/60/18 rear tyre on the stock rim without interference. I did a search but i cant find nothing clear
Thank you mates!!!
Thank you mates!!!
1983 kz 550 h
- Bozo
- Ride it like u stole it
Re: Ninja 900 gpz rear tyre question
24 Aug 2016 05:03
I have a GPZ900R rear wheel on my Z1R, 1986 I think (3.5" x 18" rim) and the maximum size I would use is 140/80. If using anything bigger the tyre will only grow in diameter and cause the bike to not handle well.
- shamal
24 Aug 2016 05:23
Thank you friend! Yes 3,5-18 its the rim.
I would love to use at least a 150. I read some where its possibile.
Someone else experience?
1983 kz 550 h
- shamal
- Bozo
24 Aug 2016 16:04 - 24 Aug 2016 16:06
After initially having the 130 the bike handled very well and the tyre looked comfortable on the rim. The 140 doesn't look wider than the 130 but it has grown in diameter (see photo, looks more like a 140/80 than a 140/70) and to be honest the 140 doesn't look as good. I would say the if you went to 150 you'll find the tyre will be less stable (although the zx900r would not feel this) and it won't look wider than the 140.
The other thing I found is that when cornering (the photo has chicken strips because the tyre was new) I can lean the 130 to the edge with no drama but the 140 (same tyre type) lets go a bit and doesn't go to the edge.
If you are doing this to make your tyre look wider, the best choice is to go for a wider rim 4 to 4.5 from the later model zx900R (I don't know how they would fit, check the zx900R forum)
Good luck.
Good luck.
Last edit: 24 Aug 2016 16:06 by Bozo.
The following user(s) said Thank You: shamal
