Rebuilding early KZ650SR rear master cylinder?
- Kray-Z
- I need more power Scotty....
20 Jul 2016 09:13
Hey, another Q? for early KZ650 gurus. I have looked for a reasonably priced piston seal and cup kit for the 14 mm M/C without any luck. Does anyone list or know where I can get the rubber parts to re-build this master cylinder? The Z1 kit is 5/8" and won't work; beside, its $100!!!!!!
Thanks.
Thanks.
- chirpy999
Re: Rebuilding early KZ650SR rear master cylinder?
20 Jul 2016 11:36
Might be cheaper to get a second handc omplete mastercylinder off a more modern bike, you might need to have a rod machined to fit. Good luck
