Throttle tube stuck to handlebar on a '78 KZ650
  • waytim
  • waytim's Avatar Topic Author
29 Jun 2016 19:31
#733333
The bike has been sitting god knows how many years. I removed the cables and housing (those actually weren't stuck) but the tube itself is just stuck like glue. The grips peeled off after reefing on it so hard. Now its just the metal tube on the handlebars. Any ideas? Thanks!
  • Nelson
  • Nelson's Avatar
Re: Throttle tube stuck to handlebar on a '78 KZ650
29 Jun 2016 21:28
#733346
soak it with penetrating oil or WD40 for a while. Then use propane torch to heat tube and expand it slightly (it will smoke a lot). Big pliers or pipe wrench to work it loose while hot. make sure no plastic is heated
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
The following user(s) said Thank You: waytim
  • waytim
29 Jun 2016 22:36
#733351
I've had it soaking all day but I don't have a torch, so I'll try to get one. Thanks for the advice!
  • davido
  • davido's Avatar
30 Jun 2016 04:05
#733359
Simpler method,to try first. Pour boiling water over it.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • waytim
30 Jun 2016 14:41
#733396
I was able to get it off by heating it up and using a pipe wrench, thanks guys!
  • Nelson
  • Nelson's Avatar
30 Jun 2016 21:36
#733440
cool!
