Rear sets
- gixxerkidd03
Rear sets
29 Jun 2016 14:43
im looking for examples and methods to mounting some sort of universal rear sets. i would like to avoid drilling a hole in my frame but if there is a clean and expectable way to do so i will. i like to see what you guys have done - photos or links are welcome. im getting sick of my OEM stance with my clubman bars- plus - ill be doing my gsxr fork swap soon. any and all advise, bickers, and banters are welcome.
cheers
cheers
1981 KZ750e
Re: Rear sets
29 Jun 2016 16:25 - 29 Jun 2016 16:26
As mentioned in the last rearset thread from two weeks ago, you can easily install GPz750 pegs on a 750E and move the pegs back a few inches. Not super rear, but very comfortable, cheap, and easy to find/install.
Last edit: 29 Jun 2016 16:26 by Nessism.
- gixxerkidd03
- gixxerkidd03
Re: Rear sets
29 Jun 2016 18:08
are you thinking the 83-85 gpz foot peg holders will bolt to my frame?
1981 KZ750e
- davido
Re: Rear sets
29 Jun 2016 23:42
You can make an adapter plate to fit on the original mounting points of the frame then pretty much bolt your new rearsets anywhere you want. I did this on my build (link below). Be sure to allow for clearance on the brake lever against the exhaust.
I made some templates out of MDF first,then when I had everything where I wanted it,just copied it out on 10mm aluminium plate.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Re: Rear sets
30 Jun 2016 07:10 - 30 Jun 2016 07:16
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
No, get the '82 GPz or the 750/700 L model pegs. You will also need the brake lever, shift lever & linkage, and the shifter mount stud.
I put a set of these on my KZ750E and it made a nice improvement.
gixxerkidd03 wrote: are you thinking the 83-85 gpz foot peg holders will bolt to my frame?
Last edit: 30 Jun 2016 07:16 by Nessism.
Re: Rear sets
30 Jun 2016 19:15
I believe Raask makes a set that will bolt right on.
- baldy110
Re: Rear sets
01 Jul 2016 10:23
For whatever reason I cannot seem to drop in a shortcut here. Under the "projects" header go to the title "Kz 750e rear sets" It has some good examples of custom rear sets.
