Fork Oil Recommendation ?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Fork Oil Recommendation ?
21 Jun 2016 20:30
#732359
It could. Air cooled motors make some noise anyway.
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
21 Jun 2016 20:34
#732362
I'll report back in a couple of days. Thanks Again !!!
77' KZ1000A
22 Jun 2016 05:57
#732391
kzdcw wrote: I have 3 different 10 wt. fork oils left over from prior motorcycle builds. Torco, Maxima, & Belray . If I combine all 3 of them, I would have enough to do both fork tubes. Not the recommended weight your guys are advising, but shouldn't pose an issue if I use these ?
What about ATF ?
I don't get it. Why are you bound and determined to put automatic transmission fluid in motorcycle forks instead of motorcycle fork oil? Fork oil doesn't cost a fortune, and since you only change it every 2 years (if the bike is properly maintained), it is not a major investment. So why not just do the right thing and buy a bottle of new fork oil? :blink: Ed
  • kzdcw
  • 77' KZ1000A
22 Jun 2016 08:32 - 22 Jun 2016 08:34
#732411
I hear you Ed, but not bound and determined to use ATF. Just was inquiring about it. Going to use what Fork Oil that I have on hand. See how that works and determine if using a heavier wt. fork oil would be better.
77' KZ1000A
Last edit: 22 Jun 2016 08:34 by kzdcw.
  • The_Proletariat
  • The_Proletariat's Avatar
  • "Cocaine is a hell of a drug"
22 Jun 2016 09:51 - 22 Jun 2016 10:00
#732420
What about ATF ?
ATF has a viscosity of a light oil and it contains powerful detergents. In addition as a lubricating oil, it also functions as a hydraulic oil inside a transmission.
Some bikes recommend ATF for fork oil (my Honda did) but I don't know of a KZ that does. If the forks are neglected running ATF for a couple hundred miles is not a bad idea to clean them out.
Some KZ's recommend motor oil for the forks as well. Obviously this does not apply to the OP but just FYI.
The biggest effect of heavier oil will be to slow down the fork rebound. Something to consider.
1982 Kawasaki KZ550 LTD
Last edit: 22 Jun 2016 10:00 by The_Proletariat.
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Jun 2016 10:38 - 22 Jun 2016 10:39
#732423
I used castrol GTX 20-50 in my forks for years. Fork oil at the dealers was crazy expensive then. Worked fine. When I bought new fork tubes, progressive springs, seals and boots, I put in 15w fork oil. The bike shop insisted I needed two. I bought one and still have some left over. The only bad thing about this is, I bought NOS boots from Z1E. Charged me $45 a piece and they cracked within the first year. I will buy new ones from z1partsinc for $22 a pair.
Live and learn. :whistle:
Last edit: 22 Jun 2016 10:39 by SWest. Reason: sp
