KZ1100 Shaft rear wheel removal
- 76KZ900
18 Jun 2016 12:20 - 18 Jun 2016 12:21
Getting ready to remove rear wheel and rear drive and replace it with a lower (numericaly) geared KZ1000 rear. Couple questions..
Ive never pulled a wheel off of a shafty .. will there be mess from gears ? Should i drain oil first?
Is there a gasket between 4 bolt flange where rear diff bolts to swingarm or just silicone ?
Anything else I need to know ?
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
76KZ900 (sold) regret
03ZRX1200R (sold) regret
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
Last edit: 18 Jun 2016 12:21 by 76KZ900.
- JoHNY
Re: KZ1100 Shaft rear wheel removal
18 Jun 2016 23:24 - 18 Jun 2016 23:25
No gasket. No, you don't need to drain any oil, just slide the wheel off the gear, If your removing the bevel box you also don't need to drain any oil but remember which way the shaft spring goes
Kawasaki Z750P7 Spectre, Triumph Daytona 955i, Honda CBR1000FN
Last edit: 18 Jun 2016 23:25 by JoHNY.
