77 Kz 650b lost keys
  • Small77fFaces
  • Small77fFaces's Avatar Topic Author
11 Jun 2016 20:26
#731016
Is there a trick to releasing the seat lock on a 77kz without a key, I have lost my keys and would like to get the seat open.
Re: 77 Kz 650b lost keys
11 Jun 2016 20:34
#731017
No eBay APP ID and/or Cert ID defined in Kunena configurationI'm not aware of a trick. However, if you look on the seat lock next to the keyhole you should see a 3 digit number. That is the key number for the lock, and you should be able to get a key made or buy one from eBay. Here's just one example (see link below). Ed
  • Small77fFaces
11 Jun 2016 20:36
#731018
Awesome, will this work for the the ignition as well?
11 Jun 2016 20:45
#731019
The 1977 KZ650 used the same key for the ignition, seat lock, and steering lock. The fuel cap can be opened with any key. Ed
  • Small77fFaces
11 Jun 2016 21:00
#731021
Thank you :):✌
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Jun 2016 07:14
#731059
650ed wrote: The 1977 KZ650 used the same key for the ignition, seat lock, and steering lock. The fuel cap can be opened with any key. Ed
Did you have one key that fit all? If not you might as well buy the whole set. :dry:
  • Small77fFaces
12 Jun 2016 07:33
#731061
Yeah I'm sure it fit everything.
