16 " rear wheel
- Outacontrol
16 " rear wheel
11 Jun 2016 08:46
Question..... will a 16" rear wheel from a kz 750 LTD fit on a kz 750e to replace the 18"
Cheers.
Cheers.
Re: 16 " rear wheel
11 Jun 2016 10:52
That depends in part on which LTD wheel you are asking about, They came with spokes, mags, drum brake, disc brake, two cylinder, four cylinder.
- Outacontrol
Re: 16 " rear wheel
11 Jun 2016 23:57
Thanks for the reply TexasKZ,
Yeah its for a four cylinder with disc brake and the alloy style mag
Re: 16 " rear wheel
12 Jun 2016 05:18
That should be a pretty straight forward swap. I just took a quick look at Kawasaki.com and I see that in 1980 those two models shared the same axle, torque link and at least one spacer. You can go there or to Partzilla.com and check all the rear wheel related part numbers for the specific year of your bike and 16 inch wheel to be sure which parts are the same.
- Outacontrol
Re: 16 " rear wheel
12 Jun 2016 05:32
Ahhh your a good man, thanks for your help and ill check those sites out.
Re: 16 " rear wheel
12 Jun 2016 05:46
You bet. Members and lurkers around here will greatly appreciate you starting a build thread with copious numbers of pictures.
