Bent Centre/paddock Stand
- razmo99
26 May 2016 18:27
Hi guys,
Can anyone tell me how to remedy a bend centre stand.
Currently when down the centre stand doesn't even lift the rear wheel off the ground.
I don't think it is the centre stand itself but the mount for the pivot shaft of the beam that the centre stand stops against.
Is this common and is their a easy solution?
- Z500 B4
-GPZ900R A9-10 ish
-GPZ900R A9-10 ish
Re: Bent Centre/paddock Stand
26 May 2016 18:30
Shocks too long?
- razmo99
26 May 2016 18:39
I have what look like the stock shocks on the bike 4-way adjustable showa's.
- Z500 B4
-GPZ900R A9-10 ish
-GPZ900R A9-10 ish
26 May 2016 18:43
Pic? Something has been changed.
- razmo99
27 May 2016 19:46Attachment IMG_1023.JPG not found
Attachment IMG_1024.JPG not found
Attachment IMG_1025.JPG not found
Attachment IMG_1026.JPG not found
Attachment IMG_1027.JPG not found
- Z500 B4
-GPZ900R A9-10 ish
-GPZ900R A9-10 ish
- razmo99
01 Jun 2016 18:05
Sorry if the photos are a bit crappy, but as you can see the centre stand goes bast where it should stop, and it just touching the cross over pipe on the exhaust, I had a spare centre stand and swapped them out and it made no difference.
What do you think is more likely, mount for the centre stand is bent or the stop is bent?
- Z500 B4
-GPZ900R A9-10 ish
-GPZ900R A9-10 ish
