Swingarm parts question
  • Tirefire Pat
  • Tirefire Pat's Avatar Topic Author
  • (2) 1980 kz1000 b-ltd,,h2-750 triple,sold.kz 550 ,
22 May 2016 05:31
#727847
I've bought a 83 vs swingarm. To swap out my 80 1000 b swing arm..however when I received the vs swingarm,,she was naked..no adjusters,axle bolts ,pivot bolt,,anything,,my questions,,willmy adjusters fit onto The gs arm? Any link where I can find the gs parts if that's what I need to do? Thanks for any input..pat
  • TexasKZ
  • TexasKZ's Avatar
Re: Swingarm parts question
22 May 2016 06:19 - 22 May 2016 06:19
#727851
If you mean GS swingarm, the last time I checked, those parts were still available at your neighborhood Suzuki dealer.
Last edit: 22 May 2016 06:19 by TexasKZ.
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 May 2016 06:21
#727852
What good is a swing arm without the hardware? Where did you get it?
  • z1kzonly
  • z1kzonly's Avatar
22 May 2016 06:41
#727855
Your Kaw pivot frame bolt will fit it they are 16mm. you do need a spacer on each side. 2 cheap hardware store 5/8" flat washers will work or machine 2 spacers about .160" - .180".
You will need a rear axle a little longer than the Kaw. The adjusters and 2 small tab piece will work.
Plus you need Suzi rear shocks with a clevis end on them at bottom.
Search ebay for those.
I showed you this pic before.
Good luck.
  • Tirefire Pat
22 May 2016 06:59
#727859
Thanks for the beta,,,and putting the pic up AGAIN,,,jeeze,,,i bought the swingarm off of a guy on here,I didn't know to find out if it came with all of the necessary parts,,valuable lesson learned,,ALL of you "experts" started somewhere,,im there
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 May 2016 07:07
#727860
I was watching one on eBay. When I started to make my own I mentioned it here. It was sold. It came complete. I should have kept my mouth shut. I have lots of others on my watch list but they don't have the hardware and won't buy them. I asked one seller but he wanted too much for it. The seller I got my arm from sold it to me complete. I wouldn't buy one any other way and won't deal with the ones that don't. :angry:
  • Tirefire Pat
22 May 2016 09:26
#727872
And here is the front end I bought,,i learned my lesson with the swingarm,,it's complete!!! Ha
