Wheel options for swapped swingarm
- 80B4
Re: Wheel options for swapped swingarm
22 May 2016 12:22
The KZ1000 police rear wheels are wider than the civilian KZ wheels. I have one mounted on my 1980 1000 ltd. I will also be using one on my 750 twin too. It will take a bit of fabrication to center the wheel and mount the caliper but nothing complicated. The police wheels are cheep and they are marked for use with tubeless tires.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- 80B4
22 May 2016 12:34
I am using a Zephyr 750 swing arm on my 1 980 1000LTD project. I have a pair of zrx1200 shocks too. I recently discovered this solution to the wider shock mounts needed to make it all work.
I will be making a pair for my project.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- 80B4
22 May 2016 12:35 - 22 May 2016 12:41
Another view.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
Last edit: 22 May 2016 12:41 by 80B4. Reason: Photo didn't show.
- nitrokeeb
22 May 2016 14:4680B4 wrote: The KZ1000 police rear wheels are wider than the civilian KZ wheels. I have one mounted on my 1980 1000 ltd. I will also be using one on my 750 twin too. It will take a bit of fabrication to center the wheel and mount the caliper but nothing complicated. The police wheels are cheep and they are marked for use with tubeless tires.
The police wheel is 18x2.5, that's narrower than the LTD wheel. They maybe wider than the Mk2/Z1R. cast 18" wheels.
I'm going to try and find out more about the V Star wheel. It would be perfect if it can be made to work.
1978 KZ1000B LTD w/KZ900 engine
- 80B4
22 May 2016 15:16
True, the Ltd wheel is a 16 inch. Not many good tires available for those rims and I am not a fan of the chopper look.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- mjg15
31 May 2016 15:22
Maybe look for a ZR550 swingarm, it's about 1" narrower than ZR750 arm IIRC. FWIW, it is about $500 to widen a wheel.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- KZ802
31 May 2016 18:21
I know you're going for the mag wheels but the spoke wheels are readily available and would require much less fabrication. It looks like the zephyr had 150-70-17 rear wheel on a 4x17 rim and you could just find kz1000A model wire wheels all over ebay cheaply. you might be able to lace up a wider rim if you wanted an even fatter tire as well.
1980 KZ750 LTDx2
1978 KZ1000 LTD
1976 KZ900 A
1978 KZ1000 LTD
1976 KZ900 A
- nitrokeeb
31 May 2016 19:47
There don't appear to be any spoke rear wheels right now on eBay. Only for a later CSR. What do they usually go for? It'll be another 2-300 on top of that for a new rim and spoke kit.
On a side note, I found out that newer sportsters run 150/80/16 tires on 16x3 wheels. STOCK. If I did do the same it would limit me to cruiser tires. What makes a tire a cruiser tire? Sport tires are soft and stocky, touring tires are longer wearing, but what about a cruiser tire?
- mjg15
31 May 2016 23:31 - 31 May 2016 23:35
www.rimspec.com/motorcycle-wheel-widening-service-by-rimspec/
www.ricks-motorcycles.com/english/Raeder/Radverbreit.htm
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
Last edit: 31 May 2016 23:35 by mjg15.
