Can I do this,and how???
- Tirefire Pat
- (2) 1980 kz1000 b-ltd,,h2-750 triple,sold.kz 550 ,
18 May 2016 09:57
Hey guys,can I swap my front-end,,,1980. 1000b....for an 07 zx6 front end???what would I have to change. Here's a pic of his zx front-end.
Attachment IMG_20160518_125345.jpg not found
- Tirefire Pat
Re: Can I do this,and how???
18 May 2016 10:01
Or would it be smarter to buy a complete front-end,, including brake system,wheel ect all together??????? Thanks for any input... Pat
- zed1015
18 May 2016 10:09 - 18 May 2016 10:10
Steering stem change ,Lock stop modification and then the front end will probably be too low causing shopping trolley handling above 100mph and the exhaust collector scraping under hard braking so you will then need a method of extending the forks by either a stepped top yoke , leg extensions or both.
If using the original 'B' wheel then there's spindle/bearing and spacer mods plus lining up the brake calipers and discs.
Last edit: 18 May 2016 10:10 by zed1015.
The following user(s) said Thank You: Tirefire Pat
- Tirefire Pat
18 May 2016 10:23
Does anyone have a recommendation as to a modern sport bike front-end that would be an ideal swap as far as length and aiding in the bikes handling on Twisty road rides...?? Pat. Thx zed
- davido
18 May 2016 10:33
Id go for (I went for) the complete front end with wheel and brakes.Far less hassle than trying to mix and match. As zed1015 says,youll need a stem swap.
As for clearance issues. Could be a problem as is .I dont know how long ZX6 forks are. ( I went for ZX9R as theyre meant to be the longest upsy dupsys available). Stepped yokes or forks extensions are a possible way around this. Many people here have done this mod before so theres lots of info on the site.Im going through it at the moment (Link in my signature) and you can also look at kawaholics 'Phoenix fighter' build thread( looks like hes going for a stepped yoke).
No idea about handling as it depends on a combination of many factors,not just the front fork length and every bike is different.Ive yet to read a thread where someone whos done this mod has experienced 'shopping trolley' handling,though to be fair that could be down to pride/emarassment! Mine hasnt turned a wheel in anger yet so I cant say one way or another. Im just plowing on with the build living in hope.
Brave or naive? Time will tell!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- zed1015
18 May 2016 11:55Tirefire Pat wrote: Or would it be smarter to buy a complete front-end,, including brake system,wheel ect all together??????? Thanks for any input... Pat
For usd's find a zx9r front end.
As stated they are just about acceptable length wise and can be lengthened internally by 32mm with a simple damper rod modification.
The stem swap is fairly easy as the std zed stem OD in the bottom yoke is the same as the zx9 stems ID at the same point so will press together with a ring of weld around the bottom inside to secure the two.
There's a small bit of machining needed on the top yoke to take the stem and to drop it a little to help gain some more frame height.
- davido
18 May 2016 13:02zed1015 wrote:Tirefire Pat wrote: Or would it be smarter to buy a complete front-end,, including brake system,wheel ect all together??????? Thanks for any input... Pat
Youve got my attention now.Whats this damper rod modification?? Need details!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- zed1015
18 May 2016 13:17 - 18 May 2016 13:26davido wrote:zed1015 wrote:Tirefire Pat wrote: Or would it be smarter to buy a complete front-end,, including brake system,wheel ect all together??????? Thanks for any input... Pat
You've got my attention now.Whats this damper rod modification?? Need details!
Basically you just extend the damper rod,preload tube and spring spacer by 32mm ( that's the max you can go ).
It's the same as I did with the ZX10R forks in my Z900 café build thread so just look on there, it'll be quicker than me explaining it again here and there's pictures there too.
Last edit: 18 May 2016 13:26 by zed1015.
The following user(s) said Thank You: davido, Tirefire Pat
